Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-31-2014, 13:12   #1 (permalink)
Member: 3212
Thanks Meter: 10
Brand adhesive used for Sony LCD mount
Hello,
I'm (almost) desparately searching for the brand of double sided tape used to mount Sony LCD/TP in het plastic frame.
As everyone can see, its not the standard 3M tape you can buy everywere around ebay. Its different, a bit thicker, foamy and has an elastic filling effect.
Can anyone provide this tape or point me in the right direction. This would make doing repairs a lot easier
Thanks.
Regards.
Old 12-18-2014, 18:56   #2 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
Hello, do you find this tape? i Searching too. I think this tape will be good for repair all phone. I try some 3M and other tape, but result is not good.
Old 12-19-2014, 10:41   #3 (permalink)
Member: 3212
Thanks Meter: 10
Hi, unfortunatly not...apparently nobody is able (or willing) to provide this tape.
Old 12-19-2014, 10:56   #4 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
Thanks for answer. If find enywhere let me know.
Old 12-19-2014, 10:59   #5 (permalink)
Member: 3212
Thanks Meter: 10
Sure no problem, if you have any progression let me also know. Thanks.
Old 12-19-2014, 11:59   #6 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
I will try this tape Double sided tape size for LCD - Digitizer? - Post #5 - XDA Forums I buy it, and waiting when i got it.
Old 04-19-2015, 20:51   #7 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
so what is the result?
Old 04-20-2015, 07:42   #8 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
sony oem not found. This tape for my link it not good for me.
Old 04-20-2015, 18:26   #9 (permalink)
Member: 1812065
did u try stellatech.com think they are in germany .
Old 04-20-2015, 18:43   #10 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
could you be more concrete?
Old 04-05-2016, 19:54   #11 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
Any news? Maybe some body find good result for double sided tape?
Old 04-06-2016, 05:00   #12 (permalink)
Member: 190184
Thanks Meter: 31
Use ordinary adhesive and then apply just a little bit of loctite 410 super glue with a toothpick or something similar on the corners. It will never come off and this super glue is easily taken off when you apply some heat making it easy if you need to replace another screen.
Old 04-06-2016, 05:17   #13 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
The thing you are looking is on aliexpress, try "double sided foam tape 0.5mm" on search.
B.R.,
Page generated in 0.26279 seconds with 9 queries
