Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-13-2009, 07:03   #1 (permalink)
Member: 866512
sony f305 keypad fault
hi friend i have a sony f305 where the keypad is not working inhe display section has well as the main pcb, i am unable to identify the keypad ic kindly help?
Old 09-09-2010, 08:14   #2 (permalink)
Member: 434631
Thanks Meter: 77
f305 all key pad hangs
f305 all key pad hangs only power key works
its software problem tested 100%
good luck.
Regd:-Tony
Old 09-09-2010, 09:52   #3 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
Thanks Meter: 140
check the side switches or check the flex cable
Old 10-04-2010, 06:34   #4 (permalink)
Member: 665335
Thanks Meter: 5
f 305 no year peace ples help
Old 10-14-2010, 19:16   #5 (permalink)
Member: 169626
Sonork: 100.1590561
Thanks Meter: 104
Smile hi
just heat the ceremics near the stip connector with flux checked in 3 sets
take care
Old 10-15-2010, 06:41   #6 (permalink)
tuhinmt's Avatar
Member: 1002743
Thanks Meter: 24
chake incomming is ok? if incomming is ok remuv all varibasin gooluck
Old 03-28-2011, 21:35   #7 (permalink)
Member: 324897
Thanks Meter: 10
w395 same problem, please post solution
Old 05-13-2011, 16:27   #8 (permalink)
Member: 1170314
Thanks Meter: 8
hai i have w395. keypad not working after switching on. i changed strip, but same problem. i flashed with setools, but same problem. can any one know the solution please tell me soon. thanks in adv
Old 06-08-2011, 15:29   #9 (permalink)
Member: 968248
Thanks Meter: 3
sony f305 keypad solution
take care
Old 06-08-2011, 15:29   #10 (permalink)
Member: 968248
Thanks Meter: 3
Old 06-10-2011, 07:11   #11 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
as me,,,its cpu problem,,,,
few days ago i got a set like this problem,,i also have do all small parts and flash..but same not work than i tried to reball cpu,,,than finally i got success,,,
so as for me if you have do all but still same pls try reball the cpu,,,but carefully its so sensative....
wish you all all the best
help abt f305 keypad tarunvishal Sony Ericsson Hardware Repair 3 07-29-2010 18:41
Sony f305 no lcd light halp plsssssssss d.jain Sony Ericsson Hardware Repair 5 07-18-2010 08:59
Hello all Sony F305? [ANSWERED] kcsystems PolarBox 3 2 11-04-2009 23:14
sony k810 keypad fault yogeshy97 Sony Ericsson Hardware Repair 1 04-06-2009 05:57
t39m no network and keypad fault sigkill Hardware Repair by brands 0 12-19-2002 12:21
Page generated in 0.23383 seconds with 9 queries
