Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-13-2010, 12:11   #1 (permalink)
Rajon_shaikh's Avatar
Member: 1306344
Sonork: 100.1590958
Thanks Meter: 84
c902 please wait help me
c902 please wait show after off light sometimes show please wait help me
Old 10-13-2010, 12:13   #2 (permalink)
sajidshah50's Avatar
Member: 1016490
Thanks Meter: 290
flash via setool
Sajid
Old 10-13-2010, 12:13   #3 (permalink)
Member: 446110
Thanks Meter: 4
just flash it and all be ok tested by me
Old 10-13-2010, 12:16   #4 (permalink)
Member: 1306344
Sonork: 100.1590958
Thanks Meter: 84
Originally Posted by sajidshah50 View Post
flash via setool
Sajid
3 times flash with setool
Old 10-13-2010, 12:25   #5 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
A)FLASHING OF A2 PHONES
common for all CID:
1. go to semc a2 tab, select proper model
2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important.
3. select in misc. field needed CUSTPACK (.zip archive with customization files)
4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash"
5. set "signed mode" on settings tab.
6. set other settings according your needs.
7. back to semc a2 tab, press flash.
CID 54,60,185,186
skip step 3,4.
B)UNLOCKING OF A2 PHONES
CID 49,51,52,53
standalone usercode reset
1. select proper model
2. on settings, check "signed mode"
3. back to semc a2 tab, press unlock
CID 49,51,52,53
standalone full reset-based unlock
2. select needed domain (leave "current" for no change)
3. on settings, check "signed mode","use alternative security bypass"
4. back to semc a2 tab, press unlock
that method can fix damaged SCRC and fixing SEMCBOOT automatically.
that is preferred method for such phones.
server-based full signature unlock
2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details
that method can not fix SCRC.
CID 80,81
if s1 signature server offline, you can not use quick (without modem drivers) unlock.
instead, you should :
"signed mode",
"disable flash mode activation for semc a2 phones",
fill login details
4. when prompted, install phone modem drivers
(they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite)
5. when you will get message "unlock done" - do not remove cable or battery,
wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure.
CID 54,60,185,186
standalone full unlock
that method can fix SCRC.
that is preferred method to unlock such phones.
C)POSSIBLE PROBLEMS AND METHODS OF REPAIR
CID 49,51,52,53
damaged trim area (ta_open errors)
1. select proper model or model,based on same chipset
2.
skip that step, if phone already r&d (brown).
convert phone to r&d (brown) domain, for that unlock phone in alternative security bypass mode with brown domain set.
3.
if your phone based on db3150 chipset - add to firmware area Shinobu_TA.ssw
if your phone based on db3200 chipset - add to firmware area elle_ta.ssw
if your phone based on db3210 chipset - add to firmware area Shiho_TA.ssw
if your phone based on db3350 chipset - add to firmware area aino_ta.ssw
4. set ecc mode: none (0)
5. on settings, check only signed mode
6. press flash
7. get gdfs package from proper model working phone, add it to misc. field
8. press write gdfs
9. unlock phone using alternative security bypass mode
10. reflash phone fully.
phone does not startup or stuck on "please wait"
CID 54
phone stuck on lg logo.
first reflash phone fully with latest firmware version.
if that not help, then
1. select proper model, on settings check only "signed mode"
2.
if your phone db3150,add to firmware area kf75x_syspart_fix.ssw
if your phone db3200, add to firmware area gt505_syspart_fix.ssw
3. press unlock
4. press clear name
5. reflash phone fully
if phone still hangs on lg logo, redo operation with different step 2:
2.
if your phone db3150,add to firmware area kf75x_syspart_fix.ssw,kf75x_drm_fix.ssw
if your phone db3200, add to firmware area gt505_syspart_fix.ssw,gt505_drm_fix.ssw
6. if needed, write gdfs package from proper model working phone, unlock phone after
CID 60,185,186
1. unlock phone
2. reflash phone
3. if needed, write gdfs package from proper model working phone, unlock phone after
Old 10-13-2010, 13:58   #6 (permalink)
Member: 173501
Thanks Meter: 15
SOny Ericsson C902
Just write GDF .i tested it
Old 10-13-2010, 15:27   #7 (permalink)
Member: 681216
Sonork: 100.1584492
Thanks Meter: 177
just write gdfs.......
Old 10-19-2010, 02:40   #8 (permalink)
vvk
Member: 46292
c902 power on black screen.
c902 power on black screen, i flash se-tool is o.k when i charger about 1 hour go back to black screen
Old 10-19-2010, 03:11   #9 (permalink)
pawans's Avatar
Member: 346345
Sonork: jhon18
Thanks Meter: 56
mates i encounter yesterday that problem.. perhaps ur firmware mismatch to ur phone.. c902 phone is two firmware one is c902 and two is c902 AS.. try to flash c902 AS your problem solve...
Old 09-07-2011, 10:51   #10 (permalink)
Member: 1614866
I've tried flashing my c902 with setool 3 time but still says please wait. What should i do.
Old 09-07-2011, 11:51   #11 (permalink)
Member: 66115
Thanks Meter: 36
frends flash this version
R3EJ001_APP_SW_1204_1731_GENERIC_AO_REDBROWNBLUE_C ID52_49_DB3150.software
R3EJ001_FS_ISRAEL_AO_REDBROWNBLUE_CID52_49.softwar e
Old 09-15-2011, 12:58   #12 (permalink)
Member: 422298
Thanks Meter: 21
C902 i flash it with c902 as
Old 11-10-2011, 17:55   #13 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
i got one with the same problem. let me flash it and i will post the result.
Old 12-01-2013, 11:23   #14 (permalink)
Member: 1680408
Sonork: 01726604159
download / sony ericsson phones / c902 / r3ej001AS flashing setool 100%ok
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.25666 seconds with 9 queries
