Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-18-2009, 23:02   #1 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
c905 BACK LIGHT PROBLEM
Hi
i have got a c905 with no back light,
it came in with top right key problem, i changed the flex,
with the new flex,soon as i put the battety in, top keypad light came on, so dissambled it again and tried the original flex in it but now i have got no back light,
i've tried this flex, top keybordm and lcd on another pcb. They work fine,
any sugesstions please
thanks
Old 06-19-2009, 20:56   #2 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
Hmmmmm............
Looks like no one has got this solution
Old 06-26-2009, 19:49   #3 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
now i have got another one with no lcd light
i have checked connectors, grips are closed properly
everything works but no lcd light.
please any expert has solution for it
thanks
Old 08-27-2009, 15:02   #4 (permalink)
ionutGSM's Avatar
Member: 44690
Thanks Meter: 22
thanks
i have same problem anyone have any ideea???
br
Old 09-03-2009, 01:08   #5 (permalink)
dejanp's Avatar
Member: 82990
Thanks Meter: 106
i have same problem too
Old 09-03-2009, 01:22   #6 (permalink)
Member: 683463
Thanks Meter: 184
also encountered this problem i replace ribbon twice still no back light at LCD
anyone has a solution please
TIA
Old 09-03-2009, 13:15   #7 (permalink)
Member: 51061
this problem due to LCD light control IC.
when the phone a while u can feel the CPU hot.
but how to fix i got no idea.
Old 09-03-2009, 19:14   #8 (permalink)
Member: 496786
Thanks Meter: 72
100% solve u r problem
i put 2k2 coil from n73 bord 100000% work change also diode from p910 bord
The Following 8 Users Say Thank You to indiatel For This Useful Post:
Old 01-28-2010, 18:31   #9 (permalink)
Member: 272137
Thanks Meter: 75
listen boss,which board is in your picture,cant get it n73 or c905 ,i put it all the way cant undrstand,can u tell me thnks in advance
The Following User Says Thank You to Repair4u For This Useful Post:
Old 02-03-2010, 10:07   #10 (permalink)
Member: 99768
Thanks Meter: 35
Yes! Goog solution, mann! It's working. I use the coil near from the big camera connector from N73 board. B.R.!
Old 02-04-2010, 13:31   #11 (permalink)
Member: 1136177
Sonork: 1613648:gsmcom
Thanks Meter: 5
please help no lcd light in c 905
Old 02-04-2010, 13:34   #12 (permalink)
dreameye's Avatar
Member: 728801
Thanks Meter: 67
i solved this by getting light coil... diode... caps.... from k850 board
try i tested with 3 sets..
Old 05-14-2011, 10:57   #13 (permalink)
Member: 1505868
i have one c905 no display back light ..........
C905 lcd light problem nsns285 Sony Ericsson Hardware Repair 77 09-05-2014 17:03
c905 lcd light problem solved indiatel Sony Ericsson Hardware Repair 16 12-27-2012 10:12
P107 LCD Back Light problem echobanoff Samsung Hardware Repair 0 04-09-2005 03:57
t100 lcd back light problem gibso Samsung Hardware Repair 6 09-13-2004 08:39
Sharp GX10i LCD back light problems oxc61 Hardware Repair by brands 1 03-31-2004 14:18
Page generated in 0.36422 seconds with 9 queries
