Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-14-2009, 11:52 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 58552 Status: Offline Thanks Meter: 24 | There is already a thread about C905 earpiece solution, but its not clear yet how to fix a problem. As i have few of them with earpiece problem. Could you please post in that thread. Just type C905 in Search box. RE Frostbite |
01-19-2009, 03:09 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: One step before you ;) Age: 42
Member: 23695 Status: Offline Sonork: 100.64383 Thanks Meter: 12 | C905 units produced before 08W45 may unfortunately have a batch problem with the PBA Key Flex Flip Complete. This can result in No Audio problem, Display problem or more unlikely GPS problem |
01-21-2009, 14:29 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: HELLAS-makedonia Age: 39
Member: 93568 Status: Offline Thanks Meter: 44 | e-techmobile you have right i just conect the right pin of earpiece to ground and WOrKs ! ! |
The Following User Says Thank You to OLYMPIOS For This Useful Post: |
01-21-2009, 14:59 | #6 (permalink) |
Junior Member Join Date: Jan 2009
Member: 952490 Status: Offline Thanks Meter: 11 | can you buy new flex? found flex on ebay. will it solve? or this is the other flex? will try to solder later, Damn phone. lots of troubles. and i have a "prototype" that someone sold to me. No warranty and it *****. |
The Following User Says Thank You to visions84 For This Useful Post: |
01-21-2009, 15:10 | #7 (permalink) |
Member: 952490 Status: Offline Thanks Meter: 11 | http://cgi.ebay.com/OEM-Slide-Flex-C...713.m153.l1262 Will this help??? |
01-21-2009, 16:41 | #9 (permalink) |
Member: 952490 Status: Offline Thanks Meter: 11 | It works but i get alot of distortion. i even got new speaker. could this be cuz theres a short of the ground or something? i did sold ground to the right pin. should i sold it direcly to the speaker instead? |
01-22-2009, 11:03 | #10 (permalink) |
Member: 952490 Status: Offline Thanks Meter: 11 | Found the distortion problem. the new speaker was broken. and i have to get new one. Which speaker is best? w850i or k800i? i tried a used k800i and it ***** bad. I remember the c905 was very good till it broke. do u know where to buy those c905? |
01-23-2009, 14:01 | #11 (permalink) |
Freak Poster Join Date: Feb 2005 Location: West Africa Age: 48
Member: 113414 Status: Offline Thanks Meter: 44 | have the same problem ,changed the ear speaker and changed the flex cable also , but the same result not not working. what i noticed while measering the values by a multimeter on the pin contacts is ok but when i put the batt and switch it on the pins contact will show a short circuit on the multimeter advice guys thx |
c905 Earpiece solution needed please. | Kurdy | Sony Ericsson Hardware Repair | 55 | 10-19-2012 09:29 |
Trick to prevent C905 Earpiece problem | pavithra_uk | Sony Ericsson Hardware Repair | 1 | 09-24-2010 16:48 |
c905 no display solution need....... plz | dreameye | Sony Ericsson Hardware Repair | 5 | 08-30-2010 09:33 |
C905 earpiece proplem..need help | kahhau | Sony Ericsson Hardware Repair | 0 | 06-10-2009 14:37 |
E2 earpiece malfunction need solution | FMC_GSM | Motorola Hardware Repair | 0 | 01-19-2008 11:35 |
