Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-10-2009, 08:29   #1 (permalink)
Member: 894150
Thanks Meter: 18
c905 Earpiece solution needed please.
Hi dear,
How are you guys? My earphone is not working anymore, only when i hold and press C button. Can somebody tell me if i can fix it if i remove this parts only:
Or what is the best sollution? I have read some threads about to solder a wire from a to b? But i dont understand?
Please help me
Thank you!
The Following 2 Users Say Thank You to Kurdy For This Useful Post:
Old 04-11-2009, 07:21   #2 (permalink)
Member: 894150
Thanks Meter: 18
I just want to know if i have to remove all the parts or just the front part? Because i dont want to dissemble my whole phone..??
Old 04-12-2009, 02:37   #3 (permalink)
Member: 210255
Thanks Meter: 12
if you have read jumper wire will fix then pal this is what you have to do to fix if you cant fix this << then take to somone else who can no futher help will be given to public people
Old 04-14-2009, 22:06   #4 (permalink)
Member: 894150
Thanks Meter: 18
Sorry for bothering, guys i just want to know if i can fix it by opening the front part only..i dont want dissemble the whole phone. and what is the easiest way to fix this problem?
Thank YOU..
Old 04-14-2009, 23:06   #5 (permalink)
medo2004's Avatar
Member: 78359
Thanks Meter: 61
u dont need to dissemble the hole phone just the front cover and make a jumper from Earpiece right leg in flex to the any earth....just do it and .........done..........
The Following User Says Thank You to medo2004 For This Useful Post:
Old 04-14-2009, 23:41   #6 (permalink)
Member: 894150
Thanks Meter: 18
Thanks for reply. U mean like this? Can u explain what u mean by jumper? connect from the gold piece to ground? or? Thankss again
The Following 11 Users Say Thank You to Kurdy For This Useful Post:
Old 04-15-2009, 10:20   #7 (permalink)
Member: 894150
Thanks Meter: 18
Guys i just want to know what jumper means.
And how will the solder work? Can someone please post a picture what i should solder and connect with?
The Following User Says Thank You to Kurdy For This Useful Post:
Old 04-15-2009, 10:26   #8 (permalink)
m&m
Member: 528287
dear you will chang the ribban or if you can give tha jumper to earpies wear
Old 04-15-2009, 13:28   #9 (permalink)
Member: 73758
change flex cable, audio chip defective(or brocken), he is outside
Old 04-15-2009, 15:42   #10 (permalink)
Member: 894150
Thanks Meter: 18
Thanks everybody, why the flex cable? Some said i cant use a small wire to connect from A to B? Or am i wrong? I will try the wire first because flex i have to dissemble everything. Can anyone show me the best way to fix it with a wire? And how can i solder it because there is nothing to solder on??? how will the wire be connected with ground?
Old 04-15-2009, 21:34   #11 (permalink)
Member: 894150
Thanks Meter: 18
Up...sorry again. But i just want my phone fixed. SE is so bad the last time. My k850 was bad, my k800 good but software problems, w800 bluetooth not working, k750 the best one, no problems at all...
Anyway please guys can someone please draw or tell me what i should solder and how??? just post a picture if you can
Thanksss
Old 04-15-2009, 22:56   #12 (permalink)
medo2004's Avatar
Member: 78359
Thanks Meter: 61
ok just do that conect wire black one from right golden to any earth or look like picture exactly and forget a to b ....jumber mean conect betwen 2 compenants.....good luck.........i will wait u to said .....its done........
Old 04-15-2009, 23:16   #13 (permalink)
Member: 894150
Thanks Meter: 18
Thank you my friend i will try it by my self today or tomorrow.
1 more question, to remove the front part, i have to remove the sticker and open the two screws behind or more?? By the way, the golden part u talking about is plain(flat), will the solder work on it? i mean will it hold the wire on it?
Old 04-15-2009, 23:28   #14 (permalink)
medo2004's Avatar
Member: 78359
Thanks Meter: 61
to remove front part u need to quied to a dissmble c905 u can find it in fourm....just use search....and the golden part as u say ..yes the solder work on it 100% and its work 100% with my way .dont ask again just do it and becarfull..or go to mobile service................good luck
Old 04-16-2009, 00:41   #15 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
Originally Posted by kurdy View Post
thanks for reply. U mean like this? Can u explain what u mean by jumper? Connect from the gold piece to ground? Or? Thankss again
tested before and working perfectly with many c905 phones. Br s a n s a r i.
C905 Earpiece solution needed.. ownage Sony Ericsson Hardware Repair 22 07-27-2011 09:08
Trick to prevent C905 Earpiece problem pavithra_uk Sony Ericsson Hardware Repair 1 09-24-2010 16:48
C905 earpiece proplem..need help kahhau Sony Ericsson Hardware Repair 0 06-10-2009 14:37
5500 Downgrade solution need PLEASE HELP maniek27 MT-BOX 3 01-30-2008 09:13
E2 earpiece malfunction need solution FMC_GSM Motorola Hardware Repair 0 01-19-2008 10:35
Page generated in 0.40877 seconds with 9 queries
