Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 09-03-2009, 19:12   #1 (permalink)
Member: 496786
Thanks Meter: 72
c905 lcd light problem solved
100% solve
i put 2k2 coil from n73 bord 100000% work change also diode from p910 bord
The Following 35 Users Say Thank You to indiatel For This Useful Post:
Old 09-29-2009, 23:47   #2 (permalink)
Member: 651628
Thanks Meter: 4
thanks I will try................
The Following User Says Thank You to ropertow For This Useful Post:
Old 09-30-2009, 22:58   #3 (permalink)
Member: 196149
Thanks Meter: 11
Thank's a lot
I try with your soulotion and it Successive 1000000000000/1000000000 go with Help for gaurd
The Following User Says Thank You to zakzak For This Useful Post:
Old 11-05-2009, 08:22   #4 (permalink)
Member: 241705
Thanks Meter: 4,294,967,295
where is l4200. c420
The Following User Says Thank You to ahmadkhan007 For This Useful Post:
Old 11-17-2009, 10:31   #5 (permalink)
Member: 787527
Thanks Meter: 2
urgent help
Originally Posted by indiatel View Post
100% solve
helo bro can you show me in picture which is 2k2 coil on n73 board ? thanks
The Following User Says Thank You to dani3lsoo For This Useful Post:
Old 02-12-2010, 17:29   #6 (permalink)
Member: 174181
Thanks Meter: 21
you can also take it from k750 (2k2 coil (220) and diode) near sim conector
The Following User Says Thank You to Jiorel For This Useful Post:
Old 02-12-2010, 18:37   #7 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
I have same problem with c905 LCD back light problem everything els is working fine any solution for me plese
The Following User Says Thank You to i am the master For This Useful Post:
Old 03-01-2010, 07:55   #8 (permalink)
Member: 518338
c905 lcd light
can take L2400 and V2440 from K750 and W800 near simcard connector
The Following User Says Thank You to pojie For This Useful Post:
Old 09-05-2010, 07:12   #9 (permalink)
rawkiss's Avatar
Member: 997585
Thanks Meter: 17
i got half display light on c905.. ive changed display n flex also... i got this problem when i tried to change d flex, before changing d flex it's light was ok... can any one help me.. i dnt think ive to change the light coil.. which is given....
The Following User Says Thank You to rawkiss For This Useful Post:
Old 05-02-2011, 18:34   #10 (permalink)
Member: 675717
Thanks Meter: 125
For me not working i have changed coil , light driver and diod no luck for display light.For display light only 4+ volt, keypad light is ok.
Old 05-06-2011, 10:57   #11 (permalink)
Member: 675717
Thanks Meter: 125
I still waiting.........................................
Old 06-26-2011, 11:42   #12 (permalink)
Member: 1520821
Sonork: 100.1641523
Thanks Meter: 40
yes you are correct brother thanks,k750,w810 also same component
The Following User Says Thank You to murali shiju For This Useful Post:
Old 02-21-2012, 12:15   #13 (permalink)
Member: 237131
Thanks Meter: 3
thanks work%100 i am test ok
Old 05-01-2012, 15:19   #14 (permalink)
Member: 1343970
Thanks Meter: 2
also you can take ciol ,diode and led driver from k800 board
Old 05-14-2012, 11:56   #15 (permalink)
Registered User
Member: 189682
Thanks Meter: 48
nace job man ................................. i use k800 220 and diode /......work 1000000%
The Following User Says Thank You to dbarakov For This Useful Post:
C905 lcd light problem nsns285 Sony Ericsson Hardware Repair 77 09-05-2014 17:03
5610 LCD light problem !!! shahzadthe1 Nokia Hardware & Hardware Repair 2 03-29-2010 21:47
C905 LCD Light way pupaji Sony Ericsson Hardware Repair 3 01-12-2010 19:08
c905 lcd light solution 1000% rajaasim Sony Ericsson Hardware Repair 1 06-10-2009 08:39
C905 lcd light heisel Sony Ericsson Hardware Repair 4 04-09-2009 19:31
Page generated in 0.34943 seconds with 10 queries
