Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-26-2007, 15:44   #1 (permalink)
Member: 377032
camera is not working in k750i
hi to all of you
well i m using k750i but its camera not working.. its says open the lens cover??
so give me some suggestions or give any trick which can make my camera working.
The Following User Says Thank You to dollar4420 For This Useful Post:
Old 05-26-2007, 15:51   #2 (permalink)
Member: 201126
its the hardware problem
check camera strip jeck or try new camera
The Following User Says Thank You to Buttsb For This Useful Post:
Old 05-26-2007, 16:16   #3 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Arrow read this
Originally Posted by dollar4420 View Post
hi to all of you
that's happend if u change ur case and during changing u break Camra lens button.
So u need to change it's camra lens. or if u understand repairing u can repair this. making a Jumper .....
or if it's not changing a case problem u need to flash the fone it's will be fine other wise u need to change camra.
also check this
take care
E
N
J
O
Y
The Following 4 Users Say Thank You to ZoHaiB_(FoneGSM) For This Useful Post:
Old 06-29-2007, 06:34   #4 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 261
hi to all of you
have same problem mate, try this solution
The Following 3 Users Say Thank You to zullu2004 For This Useful Post:
Old 06-29-2007, 06:42   #5 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
change flex ur problem will b solved
Old 06-29-2007, 19:49   #6 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
i think zullu 2004 right. most problem because lens cover switch broken so sensor to switch on camera fail. jumper two point will solved problem.
fastlink
Old 07-19-2007, 07:59   #7 (permalink)
Member: 249213
Thanks Meter: 7
Red face
jump 2 points? please post picture..i also face this problem. I tried to changed flex cable & camera lens, still the same " open the camera lens cover" please help & advice.
The Following User Says Thank You to kennyt1 For This Useful Post:
Old 07-20-2007, 13:13   #8 (permalink)
oss001's Avatar
Member: 545608
Thanks Meter: 25
hi to all of you
disconect the switch near the flash on the back of the cover am sure it will solve ur problem
Old 07-21-2007, 03:03   #9 (permalink)
Member: 257963
if i go to open camera in menus return to menus again.please help...
Old 07-21-2007, 04:33   #10 (permalink)
NizamSLM's Avatar
Member: 223302
Thanks Meter: 27
working thanks pro..........................
The Following User Says Thank You to NizamSLM For This Useful Post:
Old 02-20-2008, 15:07   #11 (permalink)
Crazy Poster
Member: 698877
Thanks Meter: 10
Hello to ALL,
whenever i open the camera from menu, it returns back to menu.I had tried changing the patta of camera but it is not working.
Please I am Requesting to all of the members please help me to solve my problem
PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PZLZ PZLZ PZLZ
Old 02-20-2008, 22:58   #12 (permalink)
Member: 701658
if i go to open camera in menus return to menus. help me
Old 02-20-2008, 22:59   #13 (permalink)
Member: 701658
thanks................
Old 04-09-2008, 14:03   #14 (permalink)
Member: 238545
Thanks Meter: 5
Thank you, this really is a solution.
Old 04-09-2008, 15:47   #15 (permalink)
Member: 745933
Same here .. would appreciate any help given.
The Following User Says Thank You to Pyr0Beast For This Useful Post:
6610i camera is not working mcell Nokia Hardware & Hardware Repair 5 05-07-2008 21:44
w810i the camera is not working shah jee Sony Ericsson 3 12-02-2006 10:10
6600 AND 6230I camera is not working, blue_moon22 Nokia Hardware & Hardware Repair 2 09-18-2006 14:04
o2x7 after unlock camera is not working topydrama77 Infinity-Box 4 05-09-2006 21:35
7250i ejheh camera is not working gadzetxp Nokia Hardware & Hardware Repair 1 07-21-2005 21:15
Page generated in 0.29592 seconds with 10 queries
