-   Sony Ericsson Hardware Repair (http://forum.gsmhosting.com/vbb/f261/)
-   -   camera is not working in k750i (http://forum.gsmhosting.com/vbb/f261/camera-not-working-k750i-406293/)
dollar4420 05-26-2007 16:44
hi to all of you
well i m using k750i but its camera not working.. its says open the lens cover??
so give me some suggestions or give any trick which can make my camera working.
Buttsb 05-26-2007 16:51
its the hardware problem
check camera strip jeck or try new camera
ZoHaiB_(FoneGSM) 05-26-2007 17:16
read this
1 Attachment(s)
Originally Posted by dollar4420 (Post 2469897)
hi to all of you
that's happend if u change ur case and during changing u break Camra lens button.
So u need to change it's camra lens. or if u understand repairing u can repair this. making a Jumper .....
or if it's not changing a case problem u need to flash the fone it's will be fine other wise u need to change camra.
also check this
take care
E
N
J
O
Y
zullu2004 06-29-2007 07:34
1 Attachment(s)
hi to all of you
have same problem mate, try this solution
jaggi 06-29-2007 07:42
change flex ur problem will b solved
fastlink Jogja 06-29-2007 20:49
i think zullu 2004 right. most problem because lens cover switch broken so sensor to switch on camera fail. jumper two point will solved problem.
fastlink
kennyt1 07-19-2007 08:59
jump 2 points? please post picture..i also face this problem. I tried to changed flex cable & camera lens, still the same " open the camera lens cover" please help & advice.:confused:
oss001 07-20-2007 14:13
hi to all of you
disconect the switch near the flash on the back of the cover am sure it will solve ur problem
bebek guling 07-21-2007 04:03
if i go to open camera in menus return to menus again.please help...
NizamSLM 07-21-2007 05:33
working thanks pro..........................
love_love2006 02-20-2008 15:07
Hello to ALL,
whenever i open the camera from menu, it returns back to menu.I had tried changing the patta of camera but it is not working.
Please I am Requesting to all of the members please help me to solve my problem
PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PLZ PZLZ PZLZ PZLZ
boss_arnaldo 02-20-2008 22:58
if i go to open camera in menus return to menus. help me
boss_arnaldo 02-20-2008 22:59
thanks................
lala321 04-09-2008 15:03
Thank you, this really is a solution.
Pyr0Beast 04-09-2008 16:47
Same here .. would appreciate any help given.
Page generated in 0.29535 seconds with 5 queries
