Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-07-2007, 10:36 | #1 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 379781 Status: Offline Thanks Meter: 9 | Can finalize flash V600i- HELP I have 2 V600i, 1 was flashed ok with R2T002 CID49. The other one just refuse to finalize. It can be flashed with R2T002/CID49, R2J005/36, R2F0015/36 using SEMC 8.4 cracked error below. I have tried R2F015 & R2J005 CID 36 BROWN, fone was originally BROWN. Tried converted to RED with no success. Thanks of the help. GUI v0.91373/UNI standalone version engaged. Card serial:00001283 Loaded 49 flash descriptors port recognized as DSS Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:36 Speed:115200 OTP status:0 locked:1 CID:36 PAF:1 IMEI:3568300048xxxx CERT:BROWN Loader:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:200D Flash props sent ok Switching to USB... Phone stays at current interface. port recognized as DSS Open COM port OK OTP status:0 locked:1 CID:36 PAF:1 IMEI:3568300048xxxx CERT:BROWN CSloader version: 050430 1711 MATCXC125904_SEMC_FILE_SYSTEM_LOADER_1_R4B loader startup: executed csloader refused to start fs services,error is:1 loader filesystem startup failed, that is fatal Elapsed:79 secs. Last edited by panlem; 07-08-2007 at 06:22. |
07-07-2007, 16:26 | #2 (permalink) |
Member: 379781 Status: Offline Thanks Meter: 9 | Solution to be tested I thought I share what I have found, although being tested if anyone test before I do please share. The solution sounds similar to this k750 problem found at http://www.esato.com/board/viewtopic...8200&start=630 basically SETool cracked (I use setool_unlock/SeTool2) has problem with RECOVERY so USE Sonics' ... Here is the solution extract: There are also certain telephones that it is necessary to upgrade the area of EROM. The k750 is common to have to upgrade the EROM. The option recovery of Setool cracked doesn't work. 1 - Makes Recovery with SonicBox. Selecione CID RED36. 2 - Writes the file of EROM: EROM_A1_DB2010_36_BROWN.bin with Setool. 3 - CID changes for RED36 with Setool. 4 - Wites the files MAIN and FS with Setool, make sure that any option this marked one in the menu Settings(NO Complet Phone). 5 - Writes the gdfs file with Setool, mark in setttings "Format GDFS." 6 - Complet phone with setool. 7 - Unlock Reapair with Setool. There are times that only writing the GDFS and making complet Phone solves this problem, but others are necessary to make the complete recovery process. Observation: Be assured of using firmware's archives new of area of unloading, the first archives were having problems, if it has doubt, better to erase the present-day archives and downloading again. [ This Message was edited by: paulobrasil on 2006-06-07 18:40 ] |
how can i flash vodafone 541....[SOLVED] | lad2 | PolarBox 3 | 3 | 03-29-2010 18:49 |
can not flash AL21 help me | dauyeuqn | E-Gold Based Phones | 5 | 04-25-2009 11:41 |
P990 can`t flash plz help | lionfinger2007 | Cruiser Suite | 2 | 03-14-2009 13:42 |
U700 can not flash, urgent help! | KUBAT1 | NSPRO | 2 | 06-28-2008 03:22 |
can.t flash u890 help | plamen40 | FuriousGold | 0 | 12-20-2006 09:25 |
