Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-03-2008, 09:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 403881 Status: Offline Thanks Meter: 80 | configuration error after flashing W580i NEED HELP URGENT, thanks in advance |
06-04-2008, 04:47 | #5 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Land Of Terror (Novus) Age: 43
Member: 530344 Status: Offline Sonork: 100.1583021 Thanks Meter: 41 | at you hey yo bro! FLASH it Again.. at this time please check the following at the settings.. :COMPLETE PHONE AFTER FLASH :UNLOCK AFTER FLASH :USE SERVER FOR CSA UNLOCK :ENABLE ALTERNATIVE BYPASS GOT IT? BR OliverouS |
The Following User Says Thank You to oliverous For This Useful Post: |
06-04-2008, 04:58 | #8 (permalink) |
Member: 530344 Status: Offline Sonork: 100.1583021 Thanks Meter: 41 | hold on TRY THIS ONE MATE... CHECK THE FOLLOWING :Complete Phone after Flash :Format GDFS When Writing if it still not WORKING, you will need the miracle of DREAM BOX... Br OliverouS |
06-04-2008, 07:30 | #12 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 496120 Status: Offline Thanks Meter: 57 | brother try to reflash flash the phone with these 4 settings. COMPLETE PHONE AFTER FLASH :UNLOCK AFTER FLASH :USE SERVER FOR CSA UNLOCK :ENABLE ALTERNATIVE BYPASS m sure ur problem must b solved Regards Ahsan |
06-04-2008, 08:33 | #14 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Quote:
Why "Format GDFS" never format GDFS in DB2020 CID52 phones and i think you need to read supported forum FAQ and for your problem "sarojrkl " if you are using SETOOL follow these steps 1st flash ur phone with files downloaded from support area using COMPLETE PHONE AFTER FLASH UNLOCK AFTER FLASH USE SERVER FOR CSA UNLOCK ENABLE ALTERNATIVE BYPASS if problem remain same then remove files and check only on these 2 options COMPLETE PHONE AFTER FLASH USE SERVER FOR CSA UNLOCK and click on flash and your problem solved | |
06-04-2008, 15:03 | #15 (permalink) | |
Member: 403881 Status: Offline Thanks Meter: 80 | Quote:
Thank you and thanks so much to all member of this forum those who came forward to help me. first of all i made a mistake that i have not mentioned I AM USING CRUISER and there following options are there shown in attached pic. while flashing i was ticked CUSTOMIZE FS AFTER FLASHING but problem is still same. Every body are requested to look into my problem. Hope positive response from all. Regards, | |
Help please - K750i configuration error after flash | MK5.ESCORT | Sony Ericsson | 6 | 12-22-2006 03:50 |
configuration error after flashing k750 | gsmservices | Cruiser Suite | 5 | 05-04-2006 10:15 |
W800i Configuration error...After Flash, Help? | citifone | Cruiser Suite | 10 | 11-28-2005 08:54 |
k500 configuration error after flash | GSMsell | Cruiser Suite | 5 | 07-24-2005 15:24 |
k 700I configuration error after flash | nanoliew | Sony Ericsson | 3 | 06-08-2005 13:50 |
