confused- how to unlock w580i- i tried every way with no sucess i am so confused i tried the whole ways to unlock my se w580i with my dcu -60 cable but no sucess there is a tutorial where you have to use first xs++ then make a unlocker patch and last you have to use setool2 i attached a picture of my result i canīt get out of this network subset i have done what was in the tutorial but after that i put an sim card and it said to me please insert the correct sim card xs++: 16:52:59| XS++ v3.2 Dev1 (Crystal) Ready ! 16:52:59| Executed on Microsoft Windows XP 16:53:05| 16:53:05| Attempting to open the interface... 16:53:05| 16:53:05| TURN OFF PHONE! 16:53:05| Hold 'C' button on phone and connect phone NOW. 16:53:05| You have 30 seconds... 16:53:05| 16:53:05| Baseband ID: 9900 16:53:05| Protocol Version: 3.1 16:53:05| Warning: IMEI name does not match GDFS name (IMEI:NULL GDFS:W580) 16:53:05| ...using GDFS name 16:53:05| 16:53:05| Profiling SEMC phone... 16:53:05| Platform: DB2020 16:53:05| OTP CID: 51 16:53:05| EROM CID: 52 16:53:05| EROM Color: Red 16:53:05| IMEI: xxxxxxxxxxxxxx 16:53:05| Phone ID: W580 16:53:05| Region: EUROPE_2 16:53:05| CDA: CDA102415/9 R1A 16:53:05| Firmware Version: R8BA024 16:53:05| EROM: R3A022 16:53:05| Ready for operation! |
bro do it on setool.. it is very easy on it |
1: open Setool 2: select model 3: select USB interface 4: go to setting TAB and check Sign Mode.............. (Use server) Do full unlock instead of user code 5: click on unlock & Repair 6: hold "C" and insert USB cable (if Require install Driver SEtool Main folder\Driver\USB_Flash _Driver) 7: when appear a message(Disconnect phone Power ON and insert sim.......etc) now you need TEST CARD 8: insert TEST CARD power ON the phone 9: connect phone (if Require install Modem Drivers) select phone mode 10: an other message will appears (disconnect phone remove battery press ready etc..........) so disconnect your phone remove battery and reinsert again hold "C" and connect again after a moment you will get UNLOCK DONE message WBR G S M - D O C T O R |
What is a TEST CARD??? Is that just a Sim or what? |
BlackBerry Bold 9700........ FULL SPECIFICATIONS...... General 2G Network GSM 850 / 900 / 1800 / 1900 3G Network HSDPA 850 / 1900 / 2100 HSDPA 1700 / 2100 / 900 Size Dimensions 109 x 60 x 14 mm Weight 122 g Display Type TFT, 65K colors Size 480 x 360 pixels, 2.44 inches Full QWERTY keyboard Touch-sensitive optical trackpad Sound Alert types Vibration; Downloadable polyphonic, MP3 ringtones Speakerphone Yes 3.5 mm audio jack Memory Phonebook Yes, Photocall Call records Yes Internal 256MB storage Card slot microSD, up to 16GB, 2GB included, buy memory Data GPRS Class 10 (4+1/3+2 slots), 32 - 48 kbps EDGE No 3G HSDPA, 3.6 Mbps WLAN Wi-Fi 802.11 b/g, UMA Bluetooth Yes, v2.1 with A2DP Infrared port No USB Yes, microUSB v2.0 Camera Primary 3.15 MP, 2048x1536 pixels, autofocus, LED flash Features Image stabilization Video Yes Secondary Features OS BlackBerry OS; 5.0 CPU 624 MHz processor Messaging SMS, MMS, Email, Instant Messaging Browser HTML Radio Games Yes + downloadable Colors Black GPS Yes, with A-GPS support Java Yes BlackBerry maps Document editor (Word, Excel, PowerPoint, PDF) Media player MP3/WMA/AAC+ Video player DivX/WMV/XviD/3gp Organizer Voice memo/dial Battery Standard battery, Li-Ion 1500 mAh Stand-by Up to 408 h Talk time Up to 6 h |
400$ usd each for quantity |
400$ - Haha, dream on sunshine, I'll use Setool flash and patch method... 400$ for a test card - that is just daylight robbery at that price, even 40$ is a silly price for a simcard even if its a test card Same card here for $9 - http://www.sw-box.com/motorola-test-card.html Tut tut @cellphoneguy |
Using this method, I took 1 CREDIT, I thought it was free??? Poor Quote:
brother it is free and not took cradit.u need only unlock sim and setool.and instal sonyericson pc suite .attach mobile add sw and fs fies.then click on identify.then u make restoration file.after it go in setting then click first three option and 5and six option leave no 4 option.and click unlock/.next option u will see on desktop .if u have any problem just [email protected] |
mxkey is cheep and best for bb |
