Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-11-2009, 15:54   #1 (permalink)
Member: 543601
confused- how to unlock w580i- i tried every way with no sucess
i am so confused
i tried the whole ways to unlock my se w580i with my dcu -60 cable
but no sucess
there is a tutorial where you have to use
first xs++
then make a unlocker patch
and last you have to use setool2
i attached a picture of my result
i canīt get out of this network subset
i have done what was in the tutorial
but after that i put an sim card
and it said to me
please insert the correct sim card
xs++:
16:52:59| XS++ v3.2 Dev1 (Crystal) Ready !
16:52:59| Executed on Microsoft Windows XP
16:53:05|
16:53:05| Attempting to open the interface...
16:53:05|
16:53:05| TURN OFF PHONE!
16:53:05| Hold 'C' button on phone and connect phone NOW.
16:53:05| You have 30 seconds...
16:53:05|
16:53:05| Baseband ID: 9900
16:53:05| Protocol Version: 3.1
16:53:05| Warning: IMEI name does not match GDFS name (IMEI:NULL GDFS:W580)
16:53:05| ...using GDFS name
16:53:05|
16:53:05| Profiling SEMC phone...
16:53:05| Platform: DB2020
16:53:05| OTP CID: 51
16:53:05| EROM CID: 52
16:53:05| EROM Color: Red
16:53:05| IMEI: xxxxxxxxxxxxxx
16:53:05| Phone ID: W580
16:53:05| Region: EUROPE_2
16:53:05| CDA: CDA102415/9 R1A
16:53:05| Firmware Version: R8BA024
16:53:05| EROM: R3A022
16:53:05| Ready for operation!
Old 04-11-2009, 16:03   #2 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
bro do it on setool.. it is very easy on it
Old 04-11-2009, 21:06   #3 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
1: open Setool
2: select model
3: select USB interface
4: go to setting TAB and check
Sign Mode.............. (Use server)
Do full unlock instead of user code
5: click on unlock & Repair
6: hold "C" and insert USB cable (if Require install Driver SEtool Main folder\Driver\USB_Flash _Driver)
7: when appear a message(Disconnect phone Power ON and insert sim.......etc)
now you need TEST CARD
8: insert TEST CARD power ON the phone
9: connect phone (if Require install Modem Drivers) select phone mode
10: an other message will appears (disconnect phone remove battery press ready etc..........)
so disconnect your phone remove battery and reinsert again
hold "C" and connect again
after a moment
you will get
UNLOCK DONE message
WBR
G S M - D O C T O R
The Following User Says Thank You to GSM-DOCTOR For This Useful Post:
Old 12-31-2009, 01:29   #4 (permalink)
Member: 877339
Thanks Meter: 15
What is a TEST CARD??? Is that just a Sim or what?
Old 12-31-2009, 01:34   #5 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Yes, it is sim card(Motorola test card)
Old 12-31-2009, 01:42   #6 (permalink)
Member: 632685
Thanks Meter: 4
BlackBerry Bold 9700........
FULL SPECIFICATIONS......
General 2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 1900 / 2100
HSDPA 1700 / 2100 / 900
Size Dimensions 109 x 60 x 14 mm
Weight 122 g
Display Type TFT, 65K colors
Size 480 x 360 pixels, 2.44 inches
Full QWERTY keyboard
Touch-sensitive optical trackpad
Sound Alert types Vibration; Downloadable polyphonic, MP3 ringtones
Speakerphone Yes
3.5 mm audio jack
Memory Phonebook Yes, Photocall
Call records Yes
Internal 256MB storage
Card slot microSD, up to 16GB, 2GB included, buy memory
Data GPRS Class 10 (4+1/3+2 slots), 32 - 48 kbps
EDGE No
3G HSDPA, 3.6 Mbps
WLAN Wi-Fi 802.11 b/g, UMA
Bluetooth Yes, v2.1 with A2DP
Infrared port No
USB Yes, microUSB v2.0
Camera Primary 3.15 MP, 2048x1536 pixels, autofocus, LED flash
Features Image stabilization
Video Yes
Secondary
Features OS BlackBerry OS; 5.0
CPU 624 MHz processor
Messaging SMS, MMS, Email, Instant Messaging
Browser HTML
Radio
Games Yes + downloadable
Colors Black
GPS Yes, with A-GPS support
Java Yes
BlackBerry maps
Document editor (Word, Excel, PowerPoint, PDF)
Media player MP3/WMA/AAC+
Video player DivX/WMV/XviD/3gp
Organizer
Voice memo/dial
Battery Standard battery, Li-Ion 1500 mAh
Stand-by Up to 408 h
Talk time Up to 6 h
Old 12-31-2009, 01:43   #7 (permalink)
Member: 632685
Thanks Meter: 4
400$ usd each for quantity
Old 12-31-2009, 01:46   #8 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Wrong section mate.
Old 12-31-2009, 13:57   #9 (permalink)
Member: 877339
Thanks Meter: 15
400$ - Haha, dream on sunshine, I'll use Setool flash and patch method...
400$ for a test card - that is just daylight robbery at that price, even 40$ is a silly price for a simcard even if its a test card
Same card here for $9 - http://www.sw-box.com/motorola-test-card.html
Tut tut @cellphoneguy
Old 12-31-2009, 16:17   #10 (permalink)
Member: 661191
Thanks Meter: 3
try to unlock with setool
Old 01-17-2010, 01:07   #11 (permalink)
Member: 877339
Thanks Meter: 15
Using this method, I took 1 CREDIT, I thought it was free??? Poor
Originally Posted by ********** View Post
1: open Setool
2: select model
after a moment
you will get
UNLOCK DONE message
WBR
G S M - D O C T O R
Old 01-18-2010, 18:29   #12 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
brother it is free and not took cradit.u need only unlock sim and setool.and instal sonyericson pc suite .attach mobile add sw and fs fies.then click on identify.then u make restoration file.after it go in setting then click first three option and 5and six option leave no 4 option.and click unlock/.next option u will see on desktop .if u have any problem just [email protected]
Old 11-02-2010, 12:36   #13 (permalink)
Member: 219420
Thanks Meter: 78
mxkey is cheep and best for bb
How to unlock w580i with only DCU-60 cable kletscher Sony Ericsson Hardware Repair 2 04-11-2009 19:13
how to unlock w580i mendones_j Sony Ericsson 3 01-08-2009 21:17
How to unlock w580i? jesuraja Sony Ericsson 3 06-17-2008 10:29
trying to unlock a Ke970 aka lg SHINE but no sucess luskanmedo FuriousGold 2 05-03-2008 16:35
How to unlock w580i with Cruiser dany_kroya81 Cruiser Suite 13 04-01-2008 12:36
Page generated in 0.22865 seconds with 9 queries
