Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-15-2004, 14:54   #1 (permalink)
Member: 3714
Crazy T66
hello
i have very strange T66 here - it cannt be powered on but when i put battery to the phone it still vibra! i see that vibra pad is one grounded but the second is shorted to vbat line, can anyone tell me where is problem? i havent got service manual to measure where is short...
thanx a lot
Platy
Old 02-17-2004, 03:12   #2 (permalink)
Brka's Avatar
Member: 163
reflow all ic's with hot air station ...
try flashing ... first language part
if all ok ... reflash mcu + ppm ...
and it must work
b.r.
Alexandar.
Old 02-23-2004, 12:26   #3 (permalink)
Member: 3714
it cannt be flashed..... it is not SW problem, vibra pad is shorted to vbat line, can anyone tell me where to dowload service manual wih layouts?
Thanx
Platy
Old 02-23-2004, 17:07   #4 (permalink)
mirko's Avatar
Member: 2993
Thanx
Platy
resold the board well with hot air + flux or better with ir station
90% of t66 has solder problem
Old 02-24-2004, 00:28   #5 (permalink)
Platijet's Avatar
Member: 26279
after your description i thing is not SW problem.
maybe is water damaged(poot pcb on ultrasonic bath) if not then you need to read schematics to find where is the short circuirt.
contact with member with nick "poca" he will help you
Old 11-01-2004, 22:47   #6 (permalink)
noname1's Avatar
Member: 12274
the vibrator driver may be short...in most cases it is a small transistor...check
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] jus_chillin Cyclonebox 19 03-29-2010 11:57
Crazy !!! Crazy !!!! crazy !!!!!!!!!!! rr44142 Nokia Multimedia 0 07-05-2006 14:22
T66 imei repair or need full flash for T66 in BIN format Kvant Sony Ericsson 5 01-16-2004 03:01
Need Crazy Help For Crazy Idea SoftSkiner GSM Programming & Reverse Engineering 7 11-27-2002 19:46
Page generated in 0.39826 seconds with 11 queries
