Damage charging port micro usb repair replacement in Sony Xperia Z C6603 solution Step by step video tutorial about charging port replacement in Xperia Z created by electronic workshop: |
I need to practise my soldering skills, do you know some good channel with good quality soldering lessons? |
You mean micro soldering, right? Considering main board repair? |
My Xperia Z3 Compact does not turning on, only red light. Do you have some tip what can I do? |
Your motherboard is damaged you need to make some soldering to get it back to work. This is how to do it: |
Red light means that the mainboard is damaged you must replace it or do some soldering stuff. |
It is damage cause by the IR1505 chip which need to be reheat or replaced. |
Reheating will not resolve the problem permanently, this method works when we need to regain the important data from the phone. |
danielsoon you are right, sometimes reheating is not enough, but it takes less time, effort and money to perform :) |
You need to perform a professional reheating stuff, it takes time! You need to choose optional flux and temperature so the whole process will be effective. |
Where can I learn more about soldering technique? |
What kind of machines do I need to do it properly? |
To learn more about soldering visit our repair forum: www.reddit.com/r/repair_tutorials/ You will find many useful guides about soldering there |
I cannot log in on your forum could you add me up, I wish to learn more about soldering repairs, thank you sir. |
