Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-21-2002, 17:02   #1 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Ericsson T20 Doesn't Start Charge When Battery Is Empty
Hi
ERICSSON T20 DOESN'T START CHARGE WHEN BATTERY IS EMPTY
when i charge battery with another T20 , and put charged battery on my phone it can charge, but if battery goes full empty, then my phone can't charge it, no poweron on charge
any solutions?????
The Following User Says Thank You to ARC For This Useful Post:
Old 03-21-2002, 17:31   #2 (permalink)
Member: 5908
just simple "brute force charging"
if you battery is good but just 1;2 v
you need
- multimeter
- stabile 5v DC (ex.: PC's power supply)
first check tha correct polarity tha battery
second connect tha righ polarity tha power supply 5-10 sec then use tha phone charger...
regards
****opig
Old 03-21-2002, 18:38   #3 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Thanks
But i already used that empty battery on another T20 and it starts charging,,,,,,,
not works on my phone only when battery is empty
Old 03-29-2002, 17:14   #4 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
still searching for solution
the problem is not from battery
i'm still searching for solution
anyone can help????????
Old 03-29-2002, 21:41   #5 (permalink)
Member: 7062
Thanks Meter: 126
please try to change the three leg transistor up to the charge conector .. if not check the three capictor round the ic power in the upper left of the pcb .... if not re hot the i c power low air max heat for about 4 sec no more it s ericsson not nokia... if not message me please ....
Old 04-02-2002, 04:44   #6 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Thanx
thanx raheeeeb
I'll try it
Old 04-03-2002, 04:00   #7 (permalink)
themobileking's Avatar
Member: 5072
Thanks Meter: 91
The PA (RM009) is probably faulty.
Try this solution.Remove the pa from the phone.You will not be able to make calls ...but don't worry ,,
now try to charge the battery normally without external charge.
90% your battery will now charge perfectly.
Please post results.
Regards,
themobileking
2600 not charging when phone is off but charging when phone is on codec_romania Nokia Digital Core Technology 4 ( DCT-4 ) 8 08-11-2005 09:31
S25,charges but battery always empty theoranking x1x to x45/x50 1 12-24-2004 10:08
t20 gets hot when battery is inserted bruce77 Old Ericsson Phones & Sony Phones 4 12-11-2004 15:13
Ericsson T20 - No Actually Charging.... ARC Sony Ericsson Hardware Repair 1 10-20-2002 20:37
t20 doesn't start up!!!!!!!!! makgsm Old Ericsson Phones & Sony Phones 0 02-20-2002 14:55
Page generated in 0.21479 seconds with 9 queries
