Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
04-01-2010, 22:50 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 367027 Status: Offline Thanks Meter: 50 | f305 display light issue |
04-03-2010, 21:24 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | Hi dear friend, try this solution ........make jumper and solve ur problem........post result |
The Following 8 Users Say Thank You to chohansahib For This Useful Post: |
05-19-2010, 05:23 | #7 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Argentina Age: 69
Member: 91019 Status: Offline Thanks Meter: 62 | i tried this and nothing I still having problem with this phones i tried the jumper and nothing, i changed the diodes and nothing... Do you have other solution?? Thank You Very Much |
09-09-2010, 08:11 | #11 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Mumbai
Member: 434631 Status: Offline Thanks Meter: 77 | F305 display light F305 display light 1st check flex 2nd change good lcd 3rd u can check diode or some thing related to hardware before checking this 2 things dont direct go to hardware.good luck |
The Following User Says Thank You to tlnadar For This Useful Post: |
09-14-2010, 07:10 | #12 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 49
Member: 118395 Status: Offline Thanks Meter: 25 | I have a problem too, i have change flex but when switch on every thing ok upto insert sim and set is white screen, change flex again but same problem, set can be switch off. when charging, after charging is display set is white screen, but charging nicely. Any solution. I have also notice that like the above picture that three ics were jumpered. |
09-14-2010, 07:29 | #13 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Paradise on Earth
Member: 385828 Status: Offline Sonork: 100.1612815 Thanks Meter: 73 | Quote:
u can get these diodes from dead boards or in samsung E700 flex cable where these switching diodes are placed near back-light circuit. these are called switching diodes u can't use normal diodes. Note: use the correct polarity. | |
SE W395 & F305 Display and Front Keypad no Light | libran_s26 | Sony Ericsson Hardware Repair | 1 | 11-15-2010 12:29 |
f305 lcd light faulty | softlinkm | Sony Ericsson Hardware Repair | 20 | 08-17-2010 05:33 |
plz halp bro f305 lcd light problem | parmodparmod | Sony Ericsson Hardware Repair | 3 | 06-08-2010 14:43 |
Keypad Light Issue on V3 | yurais | Motorola Hardware Repair | 2 | 06-07-2009 20:07 |
N73 flickering screen & background light issues | sc0ttish | Nokia Hardware & Hardware Repair | 0 | 10-02-2006 07:23 |
