Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-05-2009, 05:44 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 230110 Status: Offline Thanks Meter: 1 | gdfs startup failed SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:101010000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701501477 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 21 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:100110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701501477 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 57 secs. SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701501477 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "D:\setool\setoolff\k790\cid52\R1JC002_1250477_GEN ERIC_EV.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 612 secs. pls help |
06-05-2009, 13:28 | #3 (permalink) |
No Life Poster Join Date: May 2009 Location: On My KeyBoard
Member: 1038860 Status: Offline Sonork: 100.1593889 Thanks Meter: 173 | hi i,ve problem with 3250 nokia after flahing with version 3.24 phone dosen,t go to normal mod.test mode nd local mode is ok mobile info vrsn was 3.21 help plzzzzzzzzzzzzz |
loader GDFS startup failed, that is fatal | abuzarkhurram | SETool2 | 18 | 07-18-2009 14:36 |
z610 dead GDFS startup failed (1D) | neoBIT666 | SETool2 | 5 | 05-18-2009 18:21 |
k810 loader GDFS startup failed,help me pls | phoneshare | Sony Ericsson | 4 | 10-09-2008 19:34 |
FIXED ~loader GDFS startup failed, that is fatal~ | TDKI | SETool2 | 6 | 09-26-2008 13:51 |
W880i loader GDFS startup failed - need help | djtommy | SETool2 | 0 | 12-28-2007 10:05 |
