Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-17-2010, 13:54 | #1261 (permalink) |
Insane Poster Join Date: Aug 2006 Location: morocco
Member: 339684 Status: Offline Thanks Meter: 1 | i ve the folowing mess when i try to flash it HDR block not accepted,error: 19 i dont know what to do plz help |
The Following 3 Users Say Thank You to Hotgsm Solution For This Useful Post: |
07-19-2010, 04:53 | #1264 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 231 | plz halp bro k530i my set is hang after 1mt plz halp bro k530i my set is hang after 1mt plz halp any badi i m also software and reboil |
The Following User Says Thank You to parmodparmod For This Useful Post: |
07-19-2010, 10:35 | #1265 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1348374 Status: Offline Thanks Meter: 1 | 15/07/2010 11:55:39 PM ChipID:C900,EMP protocol:0401 15/07/2010 11:55:39 PM 15/07/2010 11:55:39 PM PHONE STATE: "RETAIL" 15/07/2010 11:55:39 PM FLASH CID: 0052 15/07/2010 11:55:42 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:XXXXXXXXXXXX CERT:RED 15/07/2010 11:55:45 PM LDR:2008-07-23 12:02 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A065 15/07/2010 11:55:45 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 15/07/2010 11:55:46 PM LDR:2009-04-21 18:09 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A081 15/07/2010 11:55:46 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 15/07/2010 11:55:46 PM writing "D:\TEMP\W595 SETUP\FLASH SOFTS\W595 FIRMWARE_1\W595_R3EG004_FS_RUSSIA_RED52.fbn" 15/07/2010 11:55:46 PM ALLOWED DOMAINS:BLUE BROWN RED 15/07/2010 11:55:46 PM MAXIMUM CID:52 15/07/2010 11:55:46 PM Will flash 597 blocks... 15/07/2010 11:56:08 PM block (84090000/00010000) not accepted,error:3B 15/07/2010 11:56:08 PM Elapsed:34 secs. I flash my W595 phone with mbn and fbn. but when u flash with fbn it displayed above error message. So pls tell me what i have to do to start my mobile ? |
The Following User Says Thank You to keymeh For This Useful Post: |
07-19-2010, 11:36 | #1266 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Madagascar Age: 35
Member: 603285 Status: Offline Thanks Meter: 31 | Quote:
tri to change our flash file with SEtool flash file or redownload our flash file!!! ifnot verifie our baterie!!! | |
The Following User Says Thank You to rvn For This Useful Post: |
07-20-2010, 14:26 | #1267 (permalink) |
Junior Member Join Date: May 2010
Member: 1305757 Status: Offline Thanks Meter: 0 | hellooooo sir firs of all i wish you to have great success in every threads... sir, i have a network problem in my w200i phone, so could you please help me to solve this problem? i hope that i could get a better reply from you thank you |
07-20-2010, 15:45 | #1268 (permalink) |
Banned Join Date: Sep 2008 Location: in ur dreams
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | sony z 610i hangs with sim otherwise works fine sony z 610i hangs with sim otherwise works fine i flash it two times with setool and ub |
07-21-2010, 07:17 | #1269 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1287416 Status: Offline Thanks Meter: 0 | Hi, I explained my problem in this thread but I will post here as well. The P1i cant be flashed. It stopped working during a phone call. Only the keyboard light is on. When try to flash it with SEUS the process could be finished (interruption at 98-99%). Tried resurrection package for P1i with XS++ and again interruption at the end. Code: 19:42:39| XS++ v3.1 (Darwin) Ready ! 19:43:11| Executing SEMC Smartphone Operations! 19:43:11| Please hold boot key ('@' or 'C') and connect device... 19:43:28| Master Port detected: COM3 19:43:28| Slave Port detected: COM4 19:43:28| Opening Port! 19:43:28| INIT MASTER...OK! 19:43:28| PHONE INFO SAMPLED...OK! 19:43:29| EPOC APPLET HEADER SENT...OK! 19:43:29| APPLET BODY SENT...OK! 19:43:29| SHUTTING DOWN MASTER...OK! 19:43:30| Baseband ID: 7100 19:43:30| Protocol Version: 3.1 19:43:30| NEW SECURITY PHONE DETECTED! SWITCHING... 19:43:31| Speed set to 460800 19:43:31| 19:43:31| Sending db2000_cid03_prodid_p3b.bin... 19:43:33| Applet ID: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B 19:43:33| This is a PRODUCTION_ID loader 19:43:33| Activating GDFS... 19:43:33| Cannot open GDFS 19:43:33| Activating GDFS... 19:43:33| Cannot open GDFS 19:43:33| Activating GDFS... 19:43:33| Cannot open GDFS 19:43:33| Warning: IMEI name does not match GDFS name (IMEI:P1 GDFS:n/a) 19:43:33| ...using IMEI name 19:43:33| 19:43:33| Profiling EPOC smartphone... 19:43:33| Platform: DB2001 19:43:33| OTP CID: 52 19:43:33| EROM CID: 53 19:43:33| EROM Color: Red 19:43:33| IMEI: 35703301xxxxxx 19:43:33| Phone ID: P1 19:43:33| Part Number: n/a 19:43:33| Phone smartphone version: R1C01 19:43:33| Phone software version: э/ 19:43:33| Processing Unit: я—]Чыv 19:43:33| Organizer: 19:43:33| CDA: 19:43:33| Activating GDFS... 19:43:33| Cannot open GDFS 19:43:33| Ready for operation! 19:44:10| 19:44:10| Parsing package contents... 19:44:10| CCPU (BABE) file: CCPU_Signaling_SW_CXC162037_R9H004_RED53.software 19:44:10| CCPU (BABE) file: CCPU_Signaling_SW_R9H004R_RED53.software 19:44:24| 19:44:24| SMARTPHONE WILL BE FLASHED IN 1 PHASE! 19:44:24| 19:44:24| [---------- PHASE 2 ----------] 19:44:24| 19:44:24| Sending db2001_cid53red_flash_r1a003.bin... 19:44:26| Applet ID: 060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 19:44:26| This is a FLASH loader 19:44:26| Flashing CCPU_Signaling_SW_CXC162037_R9H004_RED53.software 19:44:26| Header type: BABE 19:44:26| 107 flashblocks 19:47:35| Finishing flash 19:47:37| Done flashing 19:47:37| Flashing CCPU_Signaling_SW_R9H004R_RED53.software 19:47:37| Header type: BABE 19:47:37| 8 flashblocks 19:48:01| Failed sending flashblock 3. Returnvalue 0x1 19:48:01| Finishing flash Really need help. Awaiting you response. Regards. I realy need your assistance!!! |
07-21-2010, 15:22 | #1270 (permalink) |
Member: 1350129 Status: Offline Thanks Meter: 0 | C902 not working after debrand, and flash, camera/speaker etc... usual problem, i have a2uploader if that helps? i'm in the UK so a package that is western-europe or similar i guess... please help ;-) |
07-22-2010, 10:43 | #1271 (permalink) |
Member: 617031 Status: Offline Thanks Meter: 45 | brother w595 earpice problem need soltion i already changed center stripe i have doubt in speaker stripe so need speaker ways or total schemetic |
The Following User Says Thank You to yogaaa17 For This Useful Post: |
07-23-2010, 08:03 | #1273 (permalink) |
Member: 1348374 Status: Offline Thanks Meter: 1 | 15/07/2010 11:38:51 PM ChipID:C900,EMP protocol:0401 15/07/2010 11:38:51 PM 15/07/2010 11:38:51 PM PHONE STATE: "RETAIL" 15/07/2010 11:38:51 PM FLASH CID: 0052 15/07/2010 11:38:53 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:xxxxxxxxxxxx CERT:RED 15/07/2010 11:38:56 PM LDR:2008-07-23 12:02 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A065 15/07/2010 11:38:56 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 15/07/2010 11:38:58 PM LDR:2009-04-21 18:09 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A081 15/07/2010 11:38:58 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 15/07/2010 11:38:58 PM writing "D:\W595 SETUP\FLASH SOFTS\W595 FIRMWARE_3\W595_R3EF001_FS_ISRAEL_RED52.fbn" 15/07/2010 11:38:59 PM ALLOWED DOMAINS:BLUE BROWN RED 15/07/2010 11:38:59 PM MAXIMUM CID:52 15/07/2010 11:39:00 PM Will flash 628 blocks... 15/07/2010 11:39:21 PM block (84090000/00010000) not accepted,error:3B 15/07/2010 11:39:21 PM Elapsed:37 secs. I flash my W595 phone with mbn and fbn. but when u flash with fbn it displayed above error message. then i gave my mobile to mobile repairer to flash it properly. but he was not able to flash it. He found it is motherboard problem. is it true? What is the solution to solve this problem ? He told me this phone will not start now. it is useless. May i update GDFS to solve this problem ? pls suggest & guide me. |
07-23-2010, 17:27 | #1275 (permalink) |
Insane Poster Join Date: Jul 2008
Member: 812164 Status: Offline Thanks Meter: 17 | i have v 630 prob is this when i attach with pwr supply fone on properly but never with battry just once white blink change battry but no result pcb ok condition ani solution |
..::Get ALL BB5 Problems I Solved In Only 1 hours::.. | 786786 | Nokia Repair Guide and FAQ | 4179 | 03-28-2014 18:56 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
Post urs problem here solves in 24 hrs by Javajohn | Javajohn | Nokia Hardware & Hardware Repair | 92 | 06-17-2006 07:43 |
problem and solve in SL45i | Ahmed Jundy | x1x to x45/x50 | 6 | 12-31-2003 00:42 |
