Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-12-2004, 00:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | Hardware Repair Series : T610 not charging with pictures and explanation in details Lately I've been asked by many members to send them pictures I've made over time, some of them you have seen on this board, others elsewhere.... I will from this Monday forward and every new Monday post a new hardware tutorial in this section and make it sticky. So that anyone with questions can make them. After a while they will be moved to the tutorial section of this board, to be keept as reference for the future and new members. Today I'll take up the T610 Not Charging problem which I've seen lately that many have. On the T610 like many other Sony-Ericsson phones, the external circuit i.e, charger, headset ect does not have "direct" lines to the internal circuit on the board. But have been seperated by a "matrix" like many maybe know, the solution for 8310 "insert sim" which have been around for quite some while where the same kind of matrix is bypassed by shorts of certain pins. This fix we are going to do today will take advantage of the same solution, shorting some pins which seems always to get dodgy with time, and specially when the board have waterdamage. It's in my exsperience always the same pins/pads which brake down due to the fact that these pads carry the higest voltage and current on the board due to charging the battery pack. As some of you know water+cobber=nice littel battery, then these pads/pins soon turns into oxidation and corode away Tools needed for this fix : 1 : Small soldering iron max. 30 watts with SMD tip 2 : Good flux, I recommend ERSA - FMKANC32-005 non-clean cream. 3 : Some 2 mm of cobber wire 0.3 mm 4 : A good stereo micscope or lup with a minimum magnification of 20x 5 : Hot Air station with 4 mm **** tip, Air set=1.5 Heat set=3 6 : Some steady hands 1 : Carefully take away the little matrix down at the connector area, look at the first picture under here where you'll see the position of the matrix. Do it carefully and with enough flux, in order for you to keep as many undamaged solder balls intact for the time you want to mount the matrix back again. 2 : Did you get the matrix of by now ? Good, then we can continue. In the picture below here you will see a picture in 60x magnification of the area we have to work on. You will now have to make a short between the 2 pads which is cirled in red color and marked C5 and B5. On the T610's I've been working on with this fault, this one was easy quick fix, since it only required a short with a cobber wire. But take care not to destroy any of the other pads since you then have the chnace of loosing headset/flashing ect. Unless you have a new matrix, which not many have, or you have the choice of reballing it ! On other boards with this fault I've been forced to DIG down into to the board with a scalpel and find the lines since those 2 pads was totally coroded away, and then it aint easy anymore ! Hope this helps out some folks. Good luck, and dont blame me for busted boards, do this at you own risk ! IF you bust the board, send me and I'll fix. And please, do not start any "send me too" posts of any kind, they will be deleted. I do not have it whatever it might be. For your information I use a Novex AP-8 stereo microscope, and pictures posted here is taken with a QX3 Intel (tm) digital toy microscope, you can find those nice little ones on Ebay for around 60 Euro. Regards Last edited by GSM Coolhawk; 07-12-2004 at 06:45. |
The Following User Says Thank You to GSM Coolhawk For This Useful Post: |
07-22-2004, 20:20 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Europe Age: 54
Member: 24581 Status: Offline Thanks Meter: 87 | 10 min after i read this post i try this solution with working T68i and result is-working also on T68,off course i put back old IC.Regards to COOLHAWK-nice work |
08-07-2004, 19:08 | #7 (permalink) | |
Member: 7751 Status: Offline Thanks Meter: 74 | Quote:
Or another thing is that your Battery is faulty, try change to a known working one. Regards | |
09-10-2004, 02:48 | #9 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks Meter: 7 | T610 Thanx for the solution Mr GSM Coolhawk i already fixed the problem with no charging by following your step but now the phone is display blue screen . what did i do wrong? please tell me thanxxxxx |
09-29-2004, 21:57 | #12 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Crazy House Age: 41
Member: 27606 Status: Offline Thanks Meter: 15 | any idea on this problems,my t610 is charging ok and when i want to charge it when it's powered of and plug charger it power on like I switch it on on/off button |
09-30-2004, 12:06 | #13 (permalink) | |
Freak Poster Join Date: Aug 2004
Member: 77254 Status: Offline Thanks Meter: 9 | Quote:
Hardware Repair Series : 7210-6610 no power on after flash | GSM Coolhawk | Nokia Repair Guide and FAQ | 86 | 06-27-2011 11:52 |
Hardware Repair Series : 7650 Flex Fix with pictures and explanation in details | GSM Coolhawk | Nokia Repair Guide and FAQ | 17 | 12-26-2007 08:57 |
Hardware Repair Series : 8310 on/off change with pictures and explanation in details | GSM Coolhawk | Nokia Hardware & Hardware Repair | 32 | 09-27-2005 11:38 |
Hardware Repair Series: 6310i Buzzer Fix with pictures and explanation in details | GSM Coolhawk | Nokia Hardware & Hardware Repair | 1 | 12-05-2004 19:39 |
