Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-21-1999, 16:26   #1 (permalink)
Member: 75
Thanks Meter: 2
Help on doing Eric cable.
Dear sirs,I have done the Eric cable that I have found on freegsm.net but it doesn't work,I can't use neither ericserv1.8 nor emma.Could someone help me on doing PC cable?
Best Regards.
Old 05-22-1999, 18:44   #2 (permalink)
Member: 37
I had much problems with erserv32 and Win98 - try the cable under win95 - also look again, if all is soldered right, also check the pinouts of the connector, also click on the right checkbox for the com-port you are using.
- Do you have looked into system environment, if there is no hw-conflict between the com-port you are using for the cable and other devices (IRQ´s)?
Old 05-23-1999, 09:20   #3 (permalink)
Member: 75
Thanks Meter: 2
Ok I think to have solved the problem,perhaps the fault is on the adaptor that I use to com 2 that reduced the com from large to small....
Best Regards.
Do the cables of UST pro on Z3x-Box function? Service4Gsm.de Z3X-Team Products 8 06-06-2010 10:45
help on philips 760 cable UnlockerPT JAF Xtras 3 02-15-2008 23:13
Help On Samsung D600 Cable tmt539 Samsung Flashers, Software, Firmware. 7 06-29-2006 11:52
cant change imei on sony eric anymore mehta_sajid Universalbox 3 04-07-2006 16:07
Help. How do I unlock a Nokia 6185 w/a DAU Cable johnsperm0017 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-24-2002 02:30
Page generated in 0.18073 seconds with 10 queries
