Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-21-2009, 10:23 | #1 (permalink) |
Registered User Join Date: Aug 2008
Member: 844191 Status: Offline Thanks Meter: 1,293 | Sony ericson hardware picture J-100 Charing_2 J-100 Mic J-100 MIC_1 J-100 SIM WAYS J-100 speaker-1 J-100 speaker J-100 vibra j100 ear piece j100 speaker ways J200_J210 J200 buzzzer ways J200 Blue LCD J200 DISplay J200 microfon and speaker J200 ringer ways J200 SIM WAYS j200-j210i no lcd solution j200i dead J200i Joy stick J200i mic soluition j200i_mic_soluition1 j200i_riger j200_j210_joystick_ways_new_edition j200_manual j200_no_ear_piece_sound J210i joystic and keypad j210_LCD_repair J220_J230 J220 J230-keypad-ways J220_J233keypad ways j230 speaker J230 Sim Card Solution SE J230i charge J300 j300i charging j300i mic solution J300i Insert Sim J300i_joystick_solution J300i_joystick_solution2 K300 Sim Way k300i_ligt problem K200 K200i charging K300 COMPONENT PLACING K300 charging-pro k300 jostick and key ways k300 mic hand free K300 microfon K300 PA change from Mot T191 k300 ringer K300 sim ways k300-500-700 no buzzer solution k300-500-700 hadfree k300 Hand free by mic problem K300i K700 microfon K300i ptimized Charging k300i_k700i mic solution k300i_light k300_20key k300_charging_problem K300_K500_K700_key+joy K300_scheme_sim k300_yoistic K310_K510 K310 joy. K310i lcd light problem K310_Joystick solution k310_mic_ k510.rar k310 BACKLIGHT K310 auto charging k310 mic ways k310 mic ways K310 Sim Solution K310-K510-Sim Ways k310-led.rar K310-Sim K310_510_sound_IC |
The Following 35 Users Say Thank You to astig 11 For This Useful Post: |
05-21-2009, 10:23 | #2 (permalink) |
Member: 844191 Status: Offline Thanks Meter: 1,293 | K500_K508 RSI- K700,K500_Alien battery_or_Capacity_Problem COMPONENT PLACING. handfree new K300_K500_K700_key joy k500 k300 k700 Handsfree problems K500 K700 network problem 1800 or 900 k500 keypad ic bypass K500 keypad k500-SIM k500i_joystick_solution k500i_keypad_solution. k500_ ant swich k500_k508_F500_display _sche K500_Knatte chip K500_LCD_LED. K500_microphone. K500_microphone_comp_layout k500_nosim. Se k300 k500 k700 sim problem SonyEric_K500 k700 audio1 K550 K550 keys k500 mic k550 mic2 K550 charge ways K550 MIC JUMPER K600 K60x_Test_Point_and_disassembling_manual_v2 k600 power switch sche K600 system conector K600 joystick repair K600i key and joystik ways k600 key board and joystik S-E Microfon K610_V630 k610 handfree mode K610 charging K610 MIC JUMPEr K610 sim1 K610 sim2 K610 hands free K610i Micways K610i LCD K610i_V630i_sim_ways k610_mic_ways. k610_SIM t610 new on off ways K700 F700 F500 not charg 700 camera.rar k300 mic hand free copy k700 back light. K700 antenna switch. k700%20lcd k700 Modify light k700autoonof k700 component placing k700 hangat menu. k700i_hang_solution_ k700i_joystick k700 microfon k700_joystick_solutions_ mic k700 S700charge. Sony Ericsson_K700I_repair_light_display Sys conector K700 T230 LCD light not working. K750 750 volume key 1 2 3 left software key k750 Camera K750 keypad k750 w800 w700 lighat problem K750-charging k750-joystik. K750-Lsd licht K750-W800 HUNG k750 Bluetooth problem k750 charing problem k750contrast-1 K750I DISPLAY KEy PAD SOLUTION-1 K750I DISPLAY KEYPAD SOLUTION-2 k750i key pad jumper K750i_4_IN_1_cable_modify_with_Auto_Power k750i_charging1 k750I_SIM_WAYS1 k750 Joy jumper k750 keyped problem k750LCDlightjumper k750 LCD way repair k750mic. K750 on off and iluminations k750 white screen k750_cam K750_charging k750_joy_shem k750_w800_repair microphone_ k750 mmc_ Label_Info N2980_comp_placing. Part List.r repair_LED_LCD_K750_W800 Trouble_Shooting_Guide W700I MIC WAYS. zatvor camer k750 K790 |
The Following 23 Users Say Thank You to astig 11 For This Useful Post: |
05-21-2009, 10:25 | #3 (permalink) |
Member: 844191 Status: Offline Thanks Meter: 1,293 | Joystic ways k790 K790 not power on K790 k790 lcd_keypad light schematic k790_joystick_component k790_joystick_sche K790_K800_Joystick_Way K790_white _display K800 K790_K800_Joystick_Way. K800 charging problem K800 IC Missing K800 key ways K800 primary side K800 secondary side k800 speaker k800-illumination k800i keypad K800 joystick way k800 key board ways k800 lcd light k800 K800_knopki. SIM_WAYS -750 speaker M600 P800 P800 no charging P800 charging. P800 charging2 p800 signal problem p800 no charging P800_LCD_Connector P800_LCD_DC_Converter_part_ P800_N560_LCD_DC_Driver_Layout P990_P910 mic p900 P900 lcd ways P900 mic p900 speaker ways p910 p900 charge ways p900 910 not charging P990 p990 mic ways P990 charging way P990_ring ear T20 T20 self charge T68 T65_1.rar T68_Buzzer. T68_Earphone. T68_Joystick t68_joystick_connections T68_lcd T68_lights T68_lights_2 T100 ericsson_t100_solution_signal SE_t10x_antena_switch_solution solution_low_signal T100 T100 keypad t100 audio T100 ringer T100_not_charging T200 Parts on the plate T200 t200 audior epair T200 lcd T230_T290 hand free t230 PA200061 T230 jumpering glass IC T230 key 7,8,9,Up not working T230 antena switch t230 buzzer. T230 LCD light not working T230 Pic microfon T230 290 ON just with change t230ringer T230_charge. T230_charging T230_key T230_LCD_Connector T230_LCD_Connector_Layout t230_mic_detai t230_mic_repair t230_msinter T230_speaker. T230_T290 SIM ways T230_T290 keypad solution T230_T290_ keypad solution. T230_t300_sim_interface |
The Following 24 Users Say Thank You to astig 11 For This Useful Post: |
05-21-2009, 10:27 | #4 (permalink) |
Member: 844191 Status: Offline Thanks Meter: 1,293 | T300 T300_sim_interface_coom T300_sim_interface_layout. T310 T310 audio T610_T630 SOLUTION MIC 610 SOLUTION MIC T610 t610 camera ways T610 lcd ways T610 LSD. T610 MIC WAYS T610 not charging t610 sim ways T610 keys T610 Microfon T610 switch repair t610-630 buzzer way T610-T630_joystick W200 W200_k310_K510 insert sim W300 w300 keypad w300 ringer w300 charging Way w300i sim component w300i sim sche w300i-mic components w300_displaysinluz. W300_mic W300_Sim_Ways W850i ways W550 W550_Schematics + PCB. w550 LED 1 w550 LED2 w550 keypad w550i-mic jumper W550_Schematics + PCB[1].part1 W550_Schematics + PCB[1].part2 W550_Schematics + PCB[1].parrt3 W550_TP W580_s500 S500_W580_audio W600 w600_display.rar w550-power witch components W550i Side speaker jumper w550i-600 mic jumper W700 W700i mic ways W800 w800 camra k750 mic ways k750 w800 hung insert memory card k750 mic k750_w800 hang W810 k750 speaker k750_w810 audio w810 key ic jumper w810 w810 back light w810 key pad solution w810 light w810 mic w810 no lcd light W830 W830 MMc W850 W850 ways W880 W880mic W910 W910 cheeking sim ic Z200 Z200 LCD light z200 no display solution z200 charging way z200 charging Z300 Z300 sim Z800 z800 sim ic Download link |
The Following 34 Users Say Thank You to astig 11 For This Useful Post: |
05-21-2009, 10:30 | #5 (permalink) |
The Following 131 Users Say Thank You to astig 11 For This Useful Post: |
Sony ericson hardware picture all in one | caferimm68 | Sony Ericsson Hardware Repair | 9 | 01-19-2012 15:56 |
Sony ericson hardware picture all in one ! | .:DR.APE:. | Sony Ericsson Hardware Repair | 21 | 12-03-2011 08:29 |
Sony ericson hardware picture | imran_4_u | Sony Ericsson Hardware Repair | 1 | 12-05-2009 15:35 |
sony ericson hardware picture her!!!!!!!! | kramlester_14 | Sony Ericsson Hardware Repair | 2 | 07-19-2009 03:49 |
