Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 07-09-2008, 03:06   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
..::HELP K800/K810 RINGER/BUZZER have damaged/broken sound::..
Is the K800/K810 RINGER/BUZZER have damaged/broken sound when the volume is up to no.8 (maxismun level)? i have change so many new RINGER/BUZZER , but still same.
Is there any way to modify it to play a higher sounds?
In k610, even though i switch the volume to highest and the sounds are good and solid, no broken damage sound at all.
The Following User Says Thank You to hooi76 For This Useful Post:
Old 07-09-2008, 03:11   #2 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Check the two components like coils on the buzzer ways, close to the pads
Probably water damage on it.
Max_B
The Following User Says Thank You to Max_B For This Useful Post:
Old 07-09-2008, 03:53   #3 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
it's new set, there is no water damaged .
Old 07-13-2008, 22:02   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Ok Sorry for late reply
Resolder each components marked in red colour.
As well as buzzer pads has to be cleaned and resoldered.
Max_B
The Following 19 Users Say Thank You to Max_B For This Useful Post:
Old 07-15-2008, 01:35   #5 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Hi max, is the k800 ringer ic compatible with K750?
Old 07-15-2008, 04:38   #6 (permalink)
Member: 718027
Thanks Meter: 32
well mate...
this model probably got this problem...
is not the ic or component broken..
as i refer to SE service centre...
they told me that the highest volume lvl only perform when u r at the noisy environment...which mean that we only need to switch our volume lvl till max lvl 7 is enough for a normal environment...
hope this info help u...
Old 07-15-2008, 11:19   #7 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
I'm not sure, will check
Max_B
Old 07-15-2008, 15:18   #8 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
you should change power ic (n2000)
dont forget click on thanks
The Following 2 Users Say Thank You to morteza-icu For This Useful Post:
Old 07-15-2008, 15:19   #9 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
The Following User Says Thank You to morteza-icu For This Useful Post:
Old 07-16-2008, 02:48   #10 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Max_B
ok thanks for tat......
Old 07-16-2008, 10:30   #11 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
if your problem not solve by change sound ic and you have parasit in speaker and buzzer you should change power ic(ad 2012)
Old 07-19-2008, 04:10   #12 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Originally Posted by spinegy View Post
well mate...
i think u r 100% right, i test on other new k800 / k810 also same thing, the sound will break at the highest level at level 8, i forced to use at level 6~7, is there any way to modify the ring tone louder and solid like K610? The buzzer and ringing of the K610 is GREAT!
Old 10-10-2008, 12:01   #13 (permalink)
wkris's Avatar
Member: 86488
Thanks Meter: 19
Its a SOFTWARE problem!
Old 03-03-2009, 16:14   #14 (permalink)
Member: 193201
Thanks Meter: 9
I resolder components and work fine
This solution is ok
Thanks Max B
Old 03-03-2009, 16:17   #15 (permalink)
Member: 193201
Thanks Meter: 9
This solution is ok
Thanks Max B
k800 ear speaker work as ringer/Buzzer mswmkm Sony Ericsson Hardware Repair 5 11-30-2009 10:20
K800 , K810 low sound in ringer / speaker solution .. basilbaby Sony Ericsson Hardware Repair 3 10-05-2009 19:21
K800, K810, W850 easy TP 1&2 rea1One SETool2 6 03-26-2009 12:24
K800, K810, W850 easy TP 1&2 FullFLASHgSMPH DreamBox 6 02-04-2009 17:38
K800 , K810 low sound in ringer / speaker solution .. agaalias Sony Ericsson Hardware Repair 0 01-29-2009 05:51
Page generated in 0.23436 seconds with 10 queries
