Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-20-2006, 23:29   #1 (permalink)
Crazy Poster
Member: 379781
Home made flash cable?
I have modified a DCU-11 USB cable so that it is switchable between normal data cable operation and 'service' operation. I assume 'service' operation is what flash cables are. I noted that the only differences between data and service cable:
SE T28 type connection pins
USB Data cable Service cable
TX ---------- 5 --/ -- 7
RX ---------- 4 --/ -- 6
V+ ---------- 11* --/ -- 9
It is a matter of putting a swich to throw between those pins. I can not find any 3 ways switch small enough to mount at the T28 end connector so I use a jumper block with 3 removable plastic jumpers.
*I found 'charging' message enoying when trying to flash if pin 11 is left connected; you can put another jumper for it but I find easier just to put a sticky tape over pin 11 on the phone connector when flashing.
Ok, SETool2 seems to work with this cable ie. READ FLASH, GDFS but I am too chicken to try doing writes.
Questiosn please:
1) WHAT sort of cable is this modified DCU-11? I tried to find info at pinouts.ru but no luck.
2) What software will work with it? I have SETool2 but it does not seem to have T6xx support.
3) SETool2 'press power shortly!' does that mean 'press power on momentary' or 'press power when prompt shorthly'?? I intepreted the 1st.
4) Flash files seem to be cable 'brand' dependent where do I find suitable flash files for T610, T630 for this modified DCU-11?
Thankyou
Old 11-21-2006, 07:17   #2 (permalink)
Crazy Poster
Member: 379781
Follow up
hmm! reading more about this issue, it may be similar to a cruiser cable or DSS-20/25 although the switching between 'data' & 'service' is programmable rather than hard switching or jumpering.
More update, tested with Davinci client 15.8 on a T610 'Test cable' detects the phone but I am not confident enough to buy an account with DavinciTeam.com if anyone try this please confirm if it works.
SETool2 does not work with T6xx I registered with SETOOL.net looked in there archive and nothing on T6xx.
Maybe Cruiser?! will post more when I check it out.
Home made J132 cable? The Repair Shop SETool2 9 05-14-2010 12:29
★★★ Users Making home made usb/Rj45 cables Step By Step ★★★ elcapitel PolarBox 2 5 01-22-2009 13:45
LG81xx home made cable & Vygis cracked works panlem LG 0 06-13-2007 16:07
Gsm cable Home made ..::GsmHelp::.. GSM Mobile Links 2 07-06-2006 06:32
Home made cable for E365-C115 ednacell Smart-Clip 4 12-23-2004 01:09
Page generated in 0.22406 seconds with 11 queries
