Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-18-2009, 18:36 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1055873 Status: Offline Thanks Meter: 0 | how can i change my k700i's imei what does it mean and what should i do?? can anyone help me ?? i use dcu-11 cable does it matter?? |
06-18-2009, 19:36 | #2 (permalink) |
Junior Member Join Date: Nov 2004
Member: 92639 Status: Offline Thanks Meter: 0 | Connect to SETOOL2 Use the t68 cable that came with setool press C and and connect the cable to the box, if it doesn't work first time take out the battery-re-insert it press C on keypad and try connecting the cable again. If you still get "Press power on shortly" after a couple of tries it could be that the port connector on the phone is damaged,if you have another SE phone with a similar port try swapping them over, they only pull off. Cheers Hermes |
06-18-2009, 19:59 | #3 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Make sure you have the Comport selected matches the 1, in device manager for the Cable. Have cable connected, then just flick battery in when it says press power. Now the tricky bit,,, in settings you must have correct boxs ticked.. |
06-19-2009, 08:47 | #4 (permalink) |
Member: 1055873 Status: Offline Thanks Meter: 0 | i tried a lot but nothing changed i have the same problem i choose the right comport then i press flash and it says again press power on shortly it drives me crazy is there anather useful tricks?? |
06-19-2009, 11:14 | #5 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | K700 is a very old phone,,,, look at the connector at the bottom more than likely its dirty/green, get an old DRY toothbrush and scrub it, or even strip the Phone, k700 is a Very easy to strip, and Pull Black plastic of connectors and clean them. |
How can i change my IMEI? | Evolution3gp | Motorola Hardware Repair | 1 | 12-03-2007 18:09 |
How can i change k790i Cid49 imei? | Frix | FuriousGold | 1 | 11-17-2007 20:01 |
How can i change Nokia 5140 IMEI? | GSM Road Runner | Phoenix Black Box | 1 | 05-04-2005 09:41 |
How can I change my motos IMEI number ? | g0den99 | Motorola P2k | 2 | 12-27-2003 07:08 |
How can I change my IMEI back? Which software can do it? | Tom Johns | x1x to x45/x50 | 1 | 11-22-2001 08:07 |
