Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 08-21-2006, 07:46   #1 (permalink)
Member: 308794
w810 keypad problem
can any body help me, i got one SE W810i, keypad got problem, just right button cannot press, another button is ok, i got change the keypad ic upside of the keypad connecter but the problem also same....
Old 11-30-2006, 23:10   #2 (permalink)
oldsindbad's Avatar
Member: 17189
Thanks Meter: 66
well
I have the same prob.
but noticed after a while that there music player button is also nopt workin( the orange one)
very strange
asked a friend at a service center and he said it is a known error that they don't a solution for....
the just send back to SE
so if anybody that noticed this prob. could help us with a solution
thanx
Old 12-01-2006, 08:31   #3 (permalink)
Member: 388978
Thanks Meter: 88
solution repair Keyboard W810
check connector keyboard (on main board), if that is not OK, then resold IC diode brigde. If it is still that, replaced IC diode brigde.
Old 03-29-2007, 23:43   #4 (permalink)
Member: 459487
Lightbulb
I have the exact same problem - I have also read quite a few other people having this issue with those 2 buttons.
I changed keypads and issue remained.
I have just got the 2 keys to work by putting pressure on the middle back of the phone with one hand and pushing down at top and bottom of phone with other hand. Keys then work fine... so loose connection somewhere I assume. Will investigate further at the weekend and report back if I get it sorted properly.
Old 04-12-2007, 13:50   #5 (permalink)
Member: 170934
Hello,
I got the same problem here ! The orange Walkman button and the Right button are not working.
Has onyone got a sollution / schematics / sm for this problem ??
Please contact me or leave a message in this forum.
lamborghini : Where is the IC diode bridge located ??
Old 04-19-2007, 19:22   #6 (permalink)
Speed_Demon's Avatar
Member: 249757
Sonork: 100.1601084
Thanks Meter: 117
The Problem is definitly your connector. Replace or Repair.
Old 04-20-2007, 11:32   #7 (permalink)
Member: 388978
Thanks Meter: 88
i'd met same problems, the best solution that to replace new IC control keyboard. Keyboard is ok! Some myfriends is working in service centre SE also do that.
Old 04-20-2007, 11:46   #8 (permalink)
tutu1982's Avatar
Member: 193430
Thanks Meter: 123
hay its keypad ic and joystick ................
Old 06-09-2007, 13:54   #9 (permalink)
Member: 340555
Thanks Meter: 2
i have problem with w810,keypad works but no lights,does anybody have any solution,
The Following User Says Thank You to mobilephone2 For This Useful Post:
Old 09-01-2007, 18:24   #10 (permalink)
Member: 299723
Thanks Meter: 7
same problem with me
Old 06-03-2009, 02:52   #11 (permalink)
Member: 406020
Hi i have a problem with w810 keypard the middle keys 2,5,8,0 are not working ,others are working very fine and i have change new key board still the same thing, please anyone with a solution?
Old 06-03-2009, 04:15   #12 (permalink)
Registered User
Member: 171336
Thanks Meter: 61
key pad w810
replace the key pad ic
Old 07-15-2009, 15:03   #13 (permalink)
Member: 115949
Thanks Meter: 4
Hey dude where is the keypad IC?, I have changed the IC in a w800, but in the w810 where is?...
Old 08-02-2009, 10:23   #14 (permalink)
janki_amreli's Avatar
Member: 324208
Thanks Meter: 35
any one tell me where is a keyped ic ........in sony w810i...?
Old 09-08-2009, 04:33   #15 (permalink)
Member: 38888
Thanks Meter: 52
Cristal IC near to the connector.
See that: http://forum.gsmhosting.com/vbb/atta...0&d=1206253519
The Following 4 Users Say Thank You to stanimir_13 For This Useful Post:
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
w810 keypad is not working ankit_sharma Sony Ericsson Hardware Repair 0 10-01-2009 20:57
w810 keypad not work coolmax Sony Ericsson Hardware Repair 14 03-01-2009 02:34
w810 keypad problem mcman Sony Ericsson Hardware Repair 4 06-28-2008 04:43
w810 boot problem or cable problem noktune_win Cruiser Suite 2 08-23-2007 01:56
Page generated in 0.19959 seconds with 9 queries
