Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-16-2001, 18:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | Hey dude! Use a small flat screw driver and work from the bottom up to the same side. The t28s are interlocked using canals.. so you have to lift them up a little slowly. You can use specially made plastics srewdrivers for these if you don't want a little damage to the casing. And be wary of the mic connector that connects the flip to the board. |
07-16-2001, 19:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | ATTENTION!!!! don't try to remove pcb board after you have removed the screws, you can damage the BGA components. Use a hair dryer and it in the back part of the telephone (the metallic part) but not to overheat too much it, after remove the PCB. GOOD LUCK |
07-17-2001, 17:11 | #4 (permalink) |
Insane Poster Join Date: Mar 2001 Location: The Netherlands Age: 42
Member: 3702 Status: Offline Thanks Meter: 0 | hi, well i did as you siad and it worked fine!1 i used a spacial tool form my siemens C35 work set. and the casing looks just fine! i had to remove the cover because there was some thing rong with the mic. connector but i fixed it. i didn't have to remove the pcb because there was nothing rong with it but thanx any way. so i want to thank you people for replying. Greetings from holland, |
how to disassemble me45 mechanically? | eio | x1x to x45/x50 | 3 | 06-29-2003 07:18 |
how to disassembly .bin file with ida | ichsan | Siemens-Benq RingTones and WallPapers | 9 | 05-28-2003 11:18 |
how to disassemble an r520? | gaia10239 | Old Ericsson Phones & Sony Phones | 2 | 01-14-2002 11:09 |
How to disassemble Siemens SL-45? | du | Siemens Hardware Repair Area | 1 | 07-12-2001 15:17 |
How to disassemble Siemens SL-45? | du | x1x to x45/x50 | 0 | 06-22-2001 17:43 |
