Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-18-2007, 02:07 | #1 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 379781 Status: Offline Thanks Meter: 9 | How to flash K750i with cracked software? they work to flash a w800i CID36 RED but nothing works with a K750i CID 49 errors are: - Sonics; cannot recover CID49 - SeTool2: can not RECOVERY, fail to proceed with flash - SEMCTool's : error 305013 - Far: Detects but hung after click on 'FLASH' 'Activate loader got: 0 bytes' - XS++ v.1.2, v1.5, v2.xx are probably the closest I got to success. They flash files ok but failed to finalize/complete, log below. It waited for 'Waiting for the phone to completely die' forever pressing sw or remove batt, cable nothing gets a response. I also had tried with these tools using k750 TP1/2 as per cruiser but the method is probably cruiser centric. Trying to convert to CID 49 BROWN no go, CID36RED no go. Question: Sorry to ask as I don't have a good K750i to compare with so I rely on your expertise & experience, big thanks. 1) Is the log looks normal? 2) how to get pass SEMCTool error 305013? I cleaned connector, speed to 115200, batt =4.5v 3) how to get pass XS++ 'wait to complete die' ? 4) what file to use in EROM flash, I have:EROM_Brown.erom2,K750_EROM_Brown.erom2, K750_EEPROM_Area_Flash.mbn, K750_EROM_CID36_BROWN.mbn, K750_EROM_CID36_RED.mbn, W800_EEPROM_Flash_Area.mbn, W800_EROM_CID36_BROWN.mbn, W800_EROM_CID36_RED.mbn, K750-EROMwithoutFOTAdependency.mcu, EROM_A1_DB2010_36_BROWN_44000000_00020000.raw, EROM_A1_DB2010_36_RED_44000000_00020000.raw nothing seems to work. If anyone needs these files PM me. 5) which GDFS file to use? w800gdfs.gdf, w800_gdfs, K750_CID36_Red_R1J_EMEA_1.gdf. I gather any GDFS will do once I get to do GDFS (pass the complete phase) 00:13:12| Hardware Platform: db2010 Marita compact 00:13:12| Protocol Version: 3.1 00:13:13| +++ Speed set to 115200 00:13:13| +++ Phone has restarted successfully... 00:13:13| Return 00:13:13| PHONE INFO 00:13:13| DBID: db2010 00:13:13| OTP CID: 49 00:13:13| EROM CID: 49 00:13:13| EROM color: Red 00:13:13| IMEI: 35255701xxxxxx 00:13:13| Phone: K750 00:13:13| Operator: EUROPE_2 00:13:13| CDA: CDA102430/10 R7A 00:13:13| Firmware: R1DB001 00:13:13| EROM: n/a 00:13:13| 00:13:14| Ready for operation! 00:43:47| Finishing flash 00:43:47| Done flashing 00:43:47| +++ Now flashing filesystem... 00:43:51| Sending flashfile C:\Mobiles\SonyEricsson\K750-W800\K750_R1BC002_FS_THAI_RED49.bin 00:43:51| 149 flashblocks 00:58:22| Finishing flash 00:58:23| Done flashing 00:58:23| +++ Sending CS_LOADER... 00:58:23| Sending loaders\db2010_cid49red_cs_r3l.bin... 00:59:07| This is a CHIPSELECT loader 00:59:07| Activating loader... 00:59:07| Activating GDFS... 00:59:07| Checking if loader is unlocked... 00:59:07| This loader is LOCKED (errorcode=30) 00:59:07| ***** Auth startup (cmd 05-50) 00:59:07| ***** AuthA (cmd 05-42) hacking 00:59:22| Try #1000 and counting... 00:59:36| Try #2000 and counting... 00:59:51| Try #3000 and counting... 01:00:05| Try #4000 and counting... 01:00:08| ...4201 01:00:09| Matches: 0:0003940, 1:000261, 2:0000, 3:0 01:00:10| Totals : 0:0003940, 1:000261, 2:0000, 3:0 01:00:10| Theory : 0:0003938, 1:000261, 2:0001, 3:0 01:00:10| ***** Shutdown (cmd 01-08) 01:00:10| Waiting for the phone to completely die 09:47:54| ++ Error: Flashing failed 09:47:54| Disconnected... Unplug the phone |
08-11-2007, 05:49 | #2 (permalink) |
Member: 379781 Status: Offline Thanks Meter: 9 | Here is what I found One of the big problem I am having is because my K750i is CID49, CID 36 is much easier to flash. WHAT I FOUND OUT: - Sonics to recover only up to CID 36, recovery on SeTool don't work - unfortunately SEMC v8.4 croaked with error 30092 that related to dongle ie. v8.4 won't work on K750i CID49 - the best shot is to is XS++ v1.2, v1.5 - Can not down convert CID 49 to CID 36; although someone people said you can go from K750i CID49 to W800i CID 36 (?) will try once I get pass EROM issue (XS complains about not being able to activate GDFS, write GDSF not helping). - Eventhough press 'c' for USB does not work (probably 'coz of EROM) the USB-serial can connect. - many ERRORs using SEMC cracked versions are related to COMM speed, using a PL2303 will get pass this problem over MAX232 serial adaptor. - many ERRORs with SEMC still eg. 3005401 300591 CURRENT PROBLEMS: 1) Where to find K750i EROM CID49 .bin or .mbn ? 2) I got someone's CID49 EROM backup for Cruiser, HOW to convert it binary or .mbn? some pp said one can flash someone else EROM backup (?) 3) How to flash EROM CID49? maybe .mbn will work for XS that's all for now |
08-11-2007, 06:28 | #3 (permalink) |
Member: 379781 Status: Offline Thanks Meter: 9 | Basic internal Basically as I understand the internal of K750 & other SE Symptoms/fix ---------------- | Customization | non critical/ load files eg.mp3 ---------------- | File system |configuration error, locked/write gdfs, format |'complete/GDFS' |gdfs=file system, 'complete' copy system files ---------------- | Firmware | white screen, no boot/ reflash --------------- | EEPROM/EROM | all the basic operation of phone including 'c' to connect USB | | Can not activate GDFS / flash ---------------- |
08-12-2007, 13:21 | #4 (permalink) |
Member: 379781 Status: Offline Thanks Meter: 9 | SEMC v8.4 cracked Almost using this space as my blog pls feel free to share!! It seems SEMC v.8.4 can flash a K750i CID49; intended or not. If you just try to flash it normally it will says ERROR 30591 due to dongle check I guess. IF you tick [Test point] & [Skip for MAIN & FS] it will flash the phone with the selected files. BUT IT WILL NOT COMPLETE! ERRORS.... I am looking a using FAR as XS also dies: 00:02:48| 00:02:48| Ready for operation! 00:03:05| +++ Sending CS_LOADER... 00:03:06| Sending loaders\db2010_cid49red_cs_r3l.bin... 00:03:12| This is a CHIPSELECT loader 00:03:12| Activating loader... 00:03:12| Activating GDFS... 00:03:13| Checking if loader is unlocked... 00:03:13| This loader is LOCKED (errorcode=30) 00:03:13| ***** Auth startup (cmd 05-50) 00:03:13| ***** AuthA (cmd 05-42) hacking 00:03:24| Try #1000 and counting... 00:03:34| Try #2000 and counting... 00:03:45| Try #3000 and counting... 00:03:55| Try #4000 and counting... 00:03:57| ...4201 00:03:58| Matches: 0:0003949, 1:000252, 2:0000, 3:0 00:03:58| Totals : 0:0003949, 1:000252, 2:0000, 3:0 00:03:58| Theory : 0:0003938, 1:000261, 2:0001, 3:0 00:03:58| ***** Shutdown (cmd 01-08) 00:03:58| Waiting for the phone to completely die it just hang there, tried v.1.2, v.1.5, v.2.0.1. will post FAR results later, there is a tutorial for W810 that I am using as a guide. Just now it did not work... maybe my K750i CID49 has other faults I don't know, but will press on... if someone knows how, pls: I NEED K750i CID 49 EROM and how to flash with cracked software. |
HOW TO FLASH K750i BLINKING WITH SETOOL | jamohaki | Sony Ericsson | 1 | 07-02-2008 04:48 |
how to flash e313 with v15 software ? | boria | NEC | 3 | 03-31-2007 16:14 |
HOW TO UNLOCK K750i WITH UFS3 AND FBUS CABLE | miecom | Sony Ericsson | 4 | 08-10-2006 07:40 |
how to flash lgu8130 with hwk cracked | osmanabu | UFS2 + UFS3-Tornadoflasher | 4 | 11-21-2005 20:46 |
to Lead!how to flash k750i dead? | baomobile | Cruiser Suite | 3 | 09-27-2005 16:49 |
