Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-22-2003, 19:34   #1 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 283
how to remove glue under mutimodule on T68
how to remove glue under mutimodule on T68.i try remove same nokia phone but not success.can anyone help
Old 03-25-2003, 12:49   #2 (permalink)
alrbee's Avatar
Member: 7676
Thanks Meter: 4
yes , that what i want , i heared that somebody here can do that ,
plz help
Old 03-27-2003, 23:53   #3 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
You need to by glue remuwer kit (or spray) It made thet glue live in chip, not on board. Olso You can try siply remuving glued modul, but thys way PCB can be destroed...
So, look for glue remuver around. I don`t have it yet and don`t no where by it Try look aroun forum
Old 03-28-2003, 00:18   #4 (permalink)
Member: 10084
Thanks Meter: 283
@Porter
Thank for reply
Old 03-28-2003, 13:26   #5 (permalink)
genocite's Avatar
Member: 5379
i don't think that glue remover substance could work effectively, i've already tried some of it which comes from china, but none of it could work as it's said ....
Old 03-28-2003, 14:56   #6 (permalink)
evilspell's Avatar
Member: 4160
Hi,
I dont think that a chimical product exist (for Ericsson or Nokia glue)
To remove Components with glue , i use hakko 850 :
AIR : 3.5
heater: 3
between 250 ~280 C.,
first heat side of CCONT or Cobba..., till tin come out .
then continue to heat the component and use knife to pull up the compo but very slowly !
almost all glue will stay in component chip, PCB have few glue ,
then make AIR to 1, heater set to 2.5, then use knife to clean glue in PCB and that all!!!!
Old 03-28-2003, 19:51   #7 (permalink)
brka1's Avatar
Member: 4395
Thanks Meter: 159
EVILSPEEL
everything you say is ok
but for nokia phone.
did you try to remove glue from
T39 T65 or T68??????
just try with this method and ...
f**k pcb
br
Old 03-30-2003, 11:53   #8 (permalink)
Member: 461
Thanks Meter: 2
I tested “knife and air” solution to remove glued CPU on nokia 3210 , worked fine .
But only this taken many time and all i need make very carefully.
Old 04-02-2003, 21:28   #9 (permalink)
cmk
Member: 10387
Thanks Meter: 3
all model glue can remove by hotair but sonyericsson (yellow color glue like a stone )is impossibility only to exchange pcb
Old 04-03-2003, 16:05   #10 (permalink)
Member: 19294
Thanks Meter: 15
CMK&BRKA1 right
as along time go i change ccont -flash 8210- mad ( nokia ) without
problem exist but in sonyericsson is big different yellow glue
is like stone i think no chance to change this
maybe in future
Old 04-04-2003, 04:48   #11 (permalink)
Member: 10084
Thanks Meter: 283
ok all
now i can take out chip.but my PCB damage
How To Remove Glue From K610 Glue Pasted Chips sairat DreamBox 3 04-20-2008 16:57
how to remove glue on N80 /7390 MORRISGSM MT-BOX 5 09-20-2007 20:48
How to remove glue arround components? Futuro Nokia Hardware & Hardware Repair 1 01-05-2005 15:52
How to remove glue under Ccont in 8210? Trier Nokia Hardware & Hardware Repair 12 11-02-2002 01:20
How to remove glue around BGA ICs on Nokia? dimka Nokia Hardware & Hardware Repair 12 07-21-2002 19:59
Page generated in 0.21620 seconds with 9 queries
