Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-22-2013, 05:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: panadura
Member: 1183779 Status: Offline Sonork: 123 Thanks Meter: 10 | Ihave Sony Xperia sola phone no power on... |
02-22-2013, 07:15 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
Sony Xperia Sola MT27 no power bro ... sony schematic diagram of electric type is not yet out but if you need his service manual schematic try clicking service manual schematic below and hopefully you can overcome problems Sony Xperia Sola MT27 service manual + troubleshooting | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
03-16-2013, 08:12 | #3 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1901059 Status: Offline Thanks Meter: 1 | It's a battery drain issue. Already experienced the same. Plug in wall charger, leave on an hour then try to boot. Now, my problem is, phone don't charge when turned on. Only charges when off while holding power + volume up before plugin to charger. Any solution on this? Thanks! |
08-02-2014, 05:47 | #6 (permalink) |
Insane Poster Join Date: Jul 2004
Member: 74135 Status: Offline Thanks Meter: 8 | build a dummy battry to test cannot on or battery charging issue, or use another battery to try. earspeaker/loudspeaker no sound, try check the audio jack, the handfree connector might be dirty, try clean or change. if that work |
