Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-17-2008, 20:44   #1 (permalink)
Member: 926048
W810i Water damage White screen
Using unlocked w810i using from almost year and half. Just couple of month back few drops of water went inside my SEw810i. And after that white screen problem start appearing.
(No white screen blinking). I open it, and seems it was LCD damage and I found LCD connector pins were out. So replaced LCD but probelm is still there.
Phone is charging, Walkmen working I hope every things else is fine.
Going through the diff post. I but difficult to track to excat problem.
Could any one please help.
(Do I need to flash the phone)
Thanks
The Following User Says Thank You to maheshbutala For This Useful Post:
Old 12-21-2008, 16:44   #2 (permalink)
Member: 850544
Sonork: gsm king
Thanks Meter: 14
u just rehoot flash ic cpu
The Following User Says Thank You to gsmking2006 For This Useful Post:
Old 12-22-2008, 04:31   #3 (permalink)
Member: 926048
Many thanks for suggestion. But I am very falilier with this Term "Rehoot flash IC cpu"
Do you mean I should flash it again with XS++ or mean some thing else
(W810i flash ic = 5060M0Y0C0 (Intel) = M36P0R907 (ST))
Please suggest.
Thanks again
Old 12-22-2008, 04:33   #4 (permalink)
Member: 926048
Many thanks for suggestion. But I am not very familiar with this Term "Rehoot flash IC cpu"
Please suggest.
Thanks again
Old 12-31-2008, 17:28   #5 (permalink)
Member: 926048
Hi,
There is one more update. In the last week I was trying to connect my phone to PC with SE software which come with Phone. Software recognises the phone correctly and after few minutes (while connected) I can see my phone startup screen - It ask for two options "Start Phone" and "PC MODE". If select Start Phone option then screen slowly goes to White.
If put phone card it rings as well. But not able to accept the call as screen is in full white.
Old 01-01-2009, 12:40   #6 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
try this one post reply
metro2_mobilehouse
dont forget say thanks
Old 01-06-2009, 01:16   #7 (permalink)
Member: 926048
metro2mobile - Thanks for your nice solution. I am trying to go through this diagram. But difficult to read out. Could you please give the better one.
Old 01-06-2009, 20:37   #8 (permalink)
Member: 248030
Thanks Meter: 29
metro2_mobilehouse
Please dont mislead people...
This is not a solution for white display, but restart of phone when memstick is inserted..
@maheshbutala..
Examine closely lcd connector on main pcb, and clean it with a good electronic fluid like WD40...
Old 01-07-2009, 10:09   #9 (permalink)
Member: 515972
Thanks Meter: 526
@maheshbutala..
i try then post brother
what tail u?
i know this is restart of phone when memstick is inserted solution
Old 01-07-2009, 10:18   #10 (permalink)
Member: 515972
Thanks Meter: 526
brother try and post reply
[email protected]
6110 navigator water damage WHITE SCREEN MayoMohamed Nokia Hardware & Hardware Repair 1 03-20-2010 05:07
6600 water damaged - white screen realdodo Nokia Hardware & Hardware Repair 10 12-28-2007 23:22
..:;6630 water damage white light calling is ok::.. HUM Nokia Hardware & Hardware Repair 3 08-12-2007 04:34
N 70 water damage white display. maheshsaiganesh Nokia Hardware & Hardware Repair 4 02-05-2007 11:12
gd75 water damaged blank screen gorgans Panasonic 5 01-19-2004 11:53
Page generated in 0.24071 seconds with 9 queries
