Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-31-2007, 03:02   #1 (permalink)
Member: 79823
Thanks Meter: 26
J300 charging without changing IC
Hi
i have repaired a J300 charging problem with out changing the ic
all you have to do is just remove the IC and put it back on the PCB but leaving the first line of the 4 balls on the PCB means move the IC towords the mic ic and then join the 2 midle balls like in the pic,charging will be ok and no hands free problem too
i have done it and it worked perfectly 1000%
Daanish
The Following 2 Users Say Thank You to daanish For This Useful Post:
Old 05-31-2007, 20:59   #2 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up is that new
Originally Posted by daanish View Post
Hi
Daanish
dear its too old solution , i have post already , press search button , you will find it
rashid
Old 06-01-2007, 06:07   #3 (permalink)
Member: 341171
J300 Starts Charging 2 minut after conecting charger
Old 06-17-2007, 06:45   #4 (permalink)
Member: 341171
2610 Local Mode
Please its urgent
Old 06-18-2007, 00:42   #5 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up hi br
Originally Posted by wings_patel View Post
2610 Local Mode
Please its urgent
where are you wondering about , go to right section
rashid
Old 01-20-2009, 10:59   #6 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
your Problem is 100% Solved Here. Just Check this out.
J300i Not Charging Problem
Mobile Repairing Picture Help
If you like the post please HIT THANKS BUTTON
J300 charging probem ? ..::khaled::.. Sony Ericsson Hardware Repair 0 11-08-2009 14:42
here is trick for repair display without changing display ic rubel_chk007 Nokia Hardware & Hardware Repair 0 08-06-2009 05:43
j300 charging mackieP Sony Ericsson Hardware Repair 7 01-20-2009 11:02
J300 Charging Problem khalidsain Sony Ericsson Hardware Repair 0 06-29-2007 09:41
UNLOCK T18 ,T10, A1018 WITHOUT POWER SUPPLY ,WITHOUT CHANGING CABLE FOR 6** 7** 8*** MGG Old Ericsson Phones & Sony Phones 9 05-07-2000 20:33
Page generated in 0.15943 seconds with 11 queries
