Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-07-2008, 12:05 | #1 (permalink) |
Major Poster Join Date: Apr 2008
Member: 750835 Status: Offline Thanks Meter: 3 | k310 Send Superblock command NAK [email protected] v0.91380082/UNI Card serial:00028916 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35378401384829 CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R4DA044 prgCXC1250466_GENERIC_DO MAPP CXC version: R4DA044 Language Package:MEDITERR CDA article: CDA102576/4 CDA version: R5A Default article: cxc1250474 Default version: R4DA044 Operator: 000-00 USERCODE:0000 Elapsed:4 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35378401384829 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: XC1250466_GENERIC_DO_ Restore from:XC1250466_GENERIC_DO_ can't open file "G:\SE\V82\rest\XC1250466_GENERIC_DO_" writing G:\SE\V82\K310\R4GC010_1250466_GENERIC_DO.ssw CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:305 Will flash 305 blocks... Send superblock command NAK Elapsed:118 secs. DURING FLASHING K310 GIVES MESSAGE , Send Superblock command NAK PLZ HELP [email protected] |
12-07-2008, 12:19 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Badong's Junkshop
Member: 260632 Status: Offline Thanks Meter: 639 | make sure that your battery is fully charged or you can use power supply use 3.7volts then flash it again if still the same re work flash ic br |
12-07-2008, 13:26 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
try to change flash file and if u tick CSCA server than untick this option . | |
k510 can,t flashed message is comming"Send superblock command NAK" | pakmobiles | SETool2 | 2 | 05-08-2009 04:36 |
k310 Send Superblock command NAK | khalidsng | Sony Ericsson Hardware Repair | 2 | 12-25-2008 05:57 |
K800i Send superblock command NAK | Eed07 | Sony Ericsson | 4 | 10-06-2008 08:22 |
Need HELP K790i flashing | "Send superblock command NAK" | galerinisan | SETool2 | 3 | 05-29-2008 10:06 |
Send superblock command NAK ? | Prestonlad2005 | Sony Ericsson Hardware Repair | 3 | 06-08-2007 02:35 |
