Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-28-2007, 13:51   #1 (permalink)
Member: 321372
Thanks Meter: 2
k300 automatic proffile port.handfree selected
k300 no voice speaker and mic not working automatic proffile port.handfree selected
Old 03-01-2007, 22:16   #2 (permalink)
Member: 394317
Thanks Meter: 21
charging jack wash ..and change charging ic
Old 03-17-2007, 12:11   #3 (permalink)
Member: 205421
Thanks Meter: 3
yes rehoot or change charging or mic ic
Old 07-15-2007, 10:49   #4 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,590
can any one show us the solution by diagram
Old 07-15-2007, 11:04   #5 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,590
sorry buddies i got my answer and can't edit my post again
1st try to change this ic
if not work then remove this ic and mae a jumper on 2 point as shown below on the pix
Old 07-15-2007, 15:29   #6 (permalink)
Member: 259909
Thanks Meter: 4
thank u bro ,u have a gr8 job.keep it up
Old 09-22-2007, 14:43   #7 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
i remove that ic but problem still here
i also try to select the general profile manualy but after restart automaticaly port handfree selected also there are no sound in speaker only volume sound working any soloution please ?
Old 09-23-2007, 13:39   #8 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 631
dear cheng charging IC ur problem solv
Old 02-14-2008, 08:19   #9 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
K300 Port Handfree
Originally Posted by ansari123 View Post
dear cheng charging IC ur problem solve
Dear read the post again i says i already do all possible method but not working any other solution please
Old 02-14-2008, 17:58   #10 (permalink)
asrar's Avatar
Member: 264520
Thanks Meter: 61
yes... i 've same problem in my k300i. i had changed charging ic. but problem is still....
Old 02-14-2008, 18:15   #11 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 113
just service the down part of the phone,and if not ok change the charging ic.and it will be ok.
Old 02-14-2008, 19:44   #12 (permalink)
Member: 669218
Thanks Meter: 11
i have solved this problem without charging ic. i did not change the charging ic. wash the lower part of set i hope ur problem will be solve.
Old 02-15-2008, 10:29   #13 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 631
dear check this link................
http://forum.gsmhosting.com/vbb/show...60#post3089960
The Following User Says Thank You to ansari123 For This Useful Post:
Old 04-01-2008, 20:24   #14 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
thanks bro i solved the problem..........
Old 04-02-2008, 13:02   #15 (permalink)
Member: 366884
Thanks Meter: 9
i am having the same problem too, before it was mic problem, after removing and making mic ic jumpering mic became ok but phone not charging,removing and making the single jupering of the charging ic, charging became ok, supricingly auto-handfree manifested. I have solve many sony ericsson mic and charging problems but never resulted to this port-handfree.Any last solution pls
k300 k500 k700 handfree port charging and mic problem solution ansari123 Sony Ericsson Hardware Repair 59 12-25-2010 19:31
Need Nokia Automatic UFS FLASH FILE selection software... amit123 Nokia Hardware & Hardware Repair 8 10-20-2009 10:51
k600 port handfree aronlow Sony Ericsson Hardware Repair 0 09-07-2008 11:33
k300 port.handfree vinay_sharma Sony Ericsson Hardware Repair 0 12-25-2006 14:58
k300 always handfree mode shahjee Sony Ericsson Hardware Repair 2 04-12-2006 14:21
Page generated in 0.53485 seconds with 9 queries
