Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-21-2007, 15:56   #1 (permalink)
Member: 50772
k310 mic problem
k310 mic not working how to fix it ( i am change mic but no use ) any budy help me
Old 06-04-2007, 12:56   #2 (permalink)
Member: 196193
I have the same problem.....pls help.
Old 06-04-2007, 17:36   #3 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
br change mic ics near cherging ics
Old 06-08-2007, 06:59   #4 (permalink)
hooi76's Avatar
Member: 7741
where is the ic? this is not K300 this is K310
Old 06-08-2007, 09:32   #5 (permalink)
Member: 388978
pls changer Ic power.
Old 06-09-2007, 06:01   #6 (permalink)
RAMSUL's Avatar
Member: 112275
i need same problem, pls give solution
Old 06-09-2007, 15:49   #7 (permalink)
Member: 369436
i have the same problem pls help
Old 07-25-2007, 22:39   #8 (permalink)
Member: 469257
no body knows how to repait this failure??
this is a very frecuently failure, if some one may put a pic and locate where is
mic Ic will be very useful, thanks
Old 07-28-2007, 00:27   #9 (permalink)
Mourad120's Avatar
Member: 155016
In K310/510 , there is no Ic for mic since the Mic is directly wired to the IC POWER thru resistors , capacitors...so check them ..if OK ...then IC power should be Faulty..!!!!
Respects .
Old 07-29-2007, 15:31   #10 (permalink)
Member: 230911
Yes I am agree with Mr. Mourad120. He is right there is no ic for sound directly.
Old 07-30-2007, 21:28   #11 (permalink)
Member: 355410
Thumbs up hi
dont forget press thank
The Following 15 Users Say Thank You to doctormobile1 For This Useful Post:
Old 08-26-2007, 08:06   #12 (permalink)
rana_sab's Avatar
Member: 62911
I Have A K310 Mic Volume Level Is So Ow Any Soloution Please
Old 08-27-2007, 06:00   #13 (permalink)
Arief Kasali's Avatar
Member: 327733
Thumbs up K310 mic off
you can try this,im tested in my K310 the problem can solved
The Following 4 Users Say Thank You to Arief Kasali For This Useful Post:
Old 08-27-2007, 07:27   #14 (permalink)
rana_sab's Avatar
Member: 62911
Smile
Thanks alot asif bhai your soloution working 100% thanks again
Old 08-27-2007, 07:38   #15 (permalink)
rana_sab's Avatar
Member: 62911
Smile
Thanks again
k300 & k310 mic ic ratan_deb Sony Ericsson Hardware Repair Area 1 05-13-2010 16:38
k310 mic ways madhar_k Sony Ericsson Hardware Repair Area 2 03-05-2009 07:32
k310 mic problem lilan sahoo Sony Ericsson Hardware Repair Area 4 11-04-2008 16:27
k310 mic need help khai9400 Sony Ericsson Hardware Repair Area 4 08-26-2008 08:38
Page generated in 0.39819 seconds with 12 queries
