Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-07-2008, 12:05   #1 (permalink)
Member: 750835
Thanks Meter: 3
Red face k310 Send Superblock command NAK
DURING FLASHING K310 GIVES MESSAGE , Send Superblock command NAK PLZ HELP
[email protected]
v0.91380082/UNI
Card serial:00028916
Loaded 51 flash descriptors
Open COM port OK
ChipID:8040,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:49
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35378401384829 CERT:RED
FLASH CID:49 COLOR:RED
MAPP CXC article: R4DA044 prgCXC1250466_GENERIC_DO
MAPP CXC version: R4DA044
Language Package:MEDITERR
CDA article: CDA102576/4
CDA version: R5A
Default article: cxc1250474
Default version: R4DA044
Operator: 000-00
USERCODE:0000
Elapsed:4 secs.
Open COM port OK
Speed:921600
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS 'TESTPOINT OK'
Open COM port OK
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
Flash ID check:897E
Flash props sent ok
FOUND: XC1250466_GENERIC_DO_
Restore from:XC1250466_GENERIC_DO_
can't open file "G:\SE\V82\rest\XC1250466_GENERIC_DO_"
writing G:\SE\V82\K310\R4GC010_1250466_GENERIC_DO.ssw
CURRENT FLASH FILE CID:254
SSW uses dynamic hash, dynamic hash len is:305
Will flash 305 blocks...
Send superblock command NAK
Elapsed:118 secs.
[email protected]
Old 12-07-2008, 12:16   #2 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,845
try agagin with fully charged battery .
Old 12-07-2008, 12:19   #3 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 635
make sure that your battery is fully charged or you can use power supply use 3.7volts then flash it again if still the same re work flash ic
br
Old 12-07-2008, 13:26   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,522
[email protected]
v0.91380082/UNI
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
CDA version: R5A
Operator: 000-00
USERCODE:0000
Elapsed:4 secs.
Open COM port OK
Speed:921600
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed:118 secs.
[email protected]
try to change flash file and if u tick CSCA server than untick this option .
k510 can,t flashed message is comming"Send superblock command NAK" pakmobiles SETool2 2 05-08-2009 05:36
k310 Send Superblock command NAK khalidsng Sony Ericsson Hardware Repair 2 12-25-2008 05:57
K800i Send superblock command NAK Eed07 Sony Ericsson 4 10-06-2008 09:22
Need HELP K790i flashing | "Send superblock command NAK" galerinisan SETool2 3 05-29-2008 11:06
Send superblock command NAK ? Prestonlad2005 Sony Ericsson Hardware Repair 3 06-08-2007 03:35
Page generated in 0.37156 seconds with 8 queries
