Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
04-17-2005, 19:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Serbia
Member: 9165 Status: Offline Thanks Meter: 0 | K500 mic. not work which lines to check for microphone or what to shortcut? HLP. |
04-19-2005, 16:34 | #6 (permalink) | |
Member: 9165 Status: Offline Thanks Meter: 0 | Quote:
05-05-2005, 09:32 | #8 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | What is value of resistor soldered to white wire on last picture??? It seems that is mic BIAS and it won't work without it... Best regards Vule |
05-08-2005, 23:36 | #9 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | yes...there is something there, but can u be more explicit pls??? like is that resistor or L???and u solder the two capacitor togheter and the 3-rd capacitor to cristal IC....Is that all??? I have taken cristal ic from T230 but don't work for me. I have made the white wire conection, and there i have sound but very lo, and i have interference on the signal. If i take down cristal ic and make all the other conections i have just interference but no sound?µ...Regards |
05-09-2005, 00:32 | #10 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Vancouver, Canada Age: 56
Member: 26867 Status: Offline Thanks Meter: 3 | Quote:
05-09-2005, 00:48 | #11 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Normal should be same ic...T230 is same on t39, t68, t610, t630, and i think also Siemens phones c62 and CF62. This is my experience. Problem is not just cristal ic. Cristal IC broke for a reason. By changing IC reason steel same...so must find why cristal brake.... I also think that cristal can be replace by wires. Some friend told me that it is electrostatic charge protection.... so if yes it act as a multi-fuse ... Comic thing is that i have write now two F500i(same thing as k500) that have mic problem, bought cristal IC broken....on one have use t230 cristal in other p900...and nothing |
05-10-2005, 09:22 | #13 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | After changing that cristal ic i have done full reflash...but same problem-so this is not soft at all....(at least my case...) |
05-11-2005, 19:23 | #14 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | Quote:
2. re-set your phone . 3.flash your phone , if did not obey . 4.re-coupling your phone is very important. 5.clean mic interface before replacing another . 6.check your charging port for brigding . bestman | |
v3 mic not working display light ok keypad light not working | shani72 | Motorola Hardware Repair | 2 | 10-22-2009 08:15 |
1200 mic not work jampar ok bat not work pizzzzzh........................? | punitdodiya | Nokia Hardware & Hardware Repair | 5 | 09-08-2009 22:52 |
K500 keypad not working | labsmaster | Sony Ericsson Hardware Repair | 2 | 08-23-2007 20:06 |
k500 joystik not working | paklink | Sony Ericsson Hardware Repair | 3 | 06-13-2006 01:45 |
6630 mic not working need mic ways | ashok_kumar459 | Nokia Hardware & Hardware Repair | 3 | 02-13-2006 18:14 |
