Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 07-10-2005, 09:43   #1 (permalink)
Member: 93544
k500i Error flashing block at address: 0x450C0000
Please help me on k500i flashing error.
Ready!
Connecting via Fighter USB Cable...
Powering on the phone...
Phone hardware initialized OK
Analyzing configuration...
Reading primary certificate...
Primary certificate CID: 29
Primary certificate color: Red
Secondary certificate not found.
OSE configuration not found.
Done.
The phone contains recovery certificate!
Analyzing RSA protection...
RSA protection is weak.
RSA protection weakness type: PERMANENT
Flash file: "K500i_CXC125885_HongKong_R2AE033_Red29.ck5sw"
Waiting for flash file to load...
Reading phone RSA certificate...
Preparing to program flash...
Baudrate = 921600Bd
Programming flash...
Time: 00:04:10
Flash process done.
Flash file: "K500i_CXC125879_AsianLatin1_R2AE033_Red29.ck5 fs"
Script error: Flash error [4.20.68]
I flash with different flash files but still i cant fix it. Please help. what could be the problem.? Thanks
Old 08-10-2005, 19:34   #2 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Hi!
i had the same problem! chnage flash IC & do "empty board" process with SEtool3, everything will be fine.
WBR
ReyTech.
Old 08-10-2005, 20:15   #3 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
Seems to me flash IC is damaged or soldering problem.
Try to resolder flash and cpu first.
Old 08-10-2005, 20:46   #4 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
with K500 Family, when the phone comes to you Blinking, and you dont know Flash IC change process (like me = eek) Dont Flash.
Result will be stop flashing along the way, bcos fault is not flashing but 98% bad Flash IC.
But if its k700 Family, you can flash 'cos its 95% Software problem.
Sorry mate.
Old 04-28-2006, 13:13   #5 (permalink)
Member: 36907
frind same problem with me plss help me how to remove the problem plss help me
thanks in advance
Old 04-28-2006, 13:14   #6 (permalink)
Member: 36907
script error seriousely i m facing same problem
Error flashing block at address: 0x45A90000 arfantanveer Cruiser Suite 3 04-21-2009 11:12
Need HELP K790i flashing | Error flashing block at address: 0x44140000 galerinisan Cruiser Suite 4 06-03-2008 18:06
k501i always Error flashing block at address: 0x44650000 patric Cruiser Suite 17 04-14-2007 08:58
W810 dead after failed flash (Error flashing block at address: 0x444B0000) Xflame Cruiser Suite 12 12-11-2006 04:27
J300 DEAD ( Error flashing block at address: 0x0000000 aang Cruiser Suite 3 03-04-2006 18:18
Page generated in 0.20502 seconds with 9 queries
