Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-23-2008, 05:01 | #1 (permalink) |
Major Poster Join Date: Jul 2008
Member: 804530 Status: Offline Sonork: simonlow Thanks Meter: 1 | k530i cid 53 problem sim lock so if i flash it back the phone can on so what is the problem cannot anyone help me? |
08-23-2008, 05:42 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | here u go try this >flash main ang fs, in settings click signed mode (use server for bypass/csca) and complete after phone...then flash it >after flashing...identify the phone to create restoration files(dont remove the main flah file in order for the phone to create restoration file) > after identify and create restoration ...go to setting and click use server for bypass/csca and enable alternative bypass only... >then go to main software and click the unlock repair button...if asked driver install it... > and in the middle of the job the software may ask you to insert sim...if you don't have test sim then you have to insert the original sim...where the phone was lock to...(eg..vodaphone,at@t ect) ..your cellphone should be open now and in good working condition... |
The Following User Says Thank You to jawi For This Useful Post: |
08-23-2008, 09:11 | #6 (permalink) |
Member: 804530 Status: Offline Sonork: simonlow Thanks Meter: 1 | i already try to flash complete that fon..afte that second step i try to flash it bck show this SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35602702193248 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT llbug: port 282 open error: "The system cannot find the file specified" Can't open COM282(0) llbug: port 283 open error: "The system cannot find the file specified" Can't open COM283(0) PHONE FOUND AT COM2 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R6BD001_CXC1251021_HUTCHISON_NC Restore from:R6BD001_CXC1251021_HUTCHISON_NC can't open file "C:\Documents and Settings\inex\Desktop\v0.914038\rest\R6BD001_CXC12 51021_HUTCHISON_NC" LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 163 secs. what is the problem?if i unlock other fon it work ok but just this fon show this message? |
08-23-2008, 09:13 | #7 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183043 Status: Offline Thanks Meter: 68 | q: when i flashing/completing/etc phone i got error like Code: loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 734 secs.what to do ? a: that error can be caused by different problems. lets see all of them 1. user has run "executor" application, which was not deleted after "new altbypass unlock". solution - select correct model on settings check only "use preloader security bypass". execute any operation, say : "read flash" 2. main software somehow has been damaged (cause of free tools, etc) solution - select correct model on settings check only "use signed mode". add to firmware area only main part of firmware press flash (use com/ufs or dcu60 with "2+5" keys if phone not connecting with "C" ) after that, phone should show identify normally. .... and if not.... 3. gdfs area has been damaged (bad flash ic, firmware error,etc) solution - a) install empty flash chip and do emptyboard fill procedure b) try to repair gdfs area with VERY complex testpoints c) change both mcu+flash chip from other phone |
08-23-2008, 09:37 | #8 (permalink) |
Member: 804530 Status: Offline Sonork: simonlow Thanks Meter: 1 | so that means if sony k530i cid 53 cannot open sim lock ?i use the same step to open this model k530i but show that message above ?so can any body give me solution?help me |
09-27-2008, 12:09 | #9 (permalink) |
Freak Poster Join Date: Dec 2007 Location: nepal
Member: 655012 Status: Offline Thanks Meter: 26 | sony k530i cid 53 how to unoock v0.914038/UNI CARD SERIAL: 00049461 Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35901901402403 Model:K530c Brand:Generic MAPP CXC article: R8BA024 prgCXC1251059_CHINA_NS MAPP CXC version: R8BA024 Language Package:CHINA CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1251063 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 7 secs. SIGNED MODE (USING SERVER). PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 7 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 11 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed resetting USERCODE.. smth wrong with usercode reset,error is: 1 Error while resetting USERCODE. Elapsed: 51 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\com81\Desktop\K530 cid 53 files\r8ba024_cxc1251059_ns_red_cid53.software CURRENT FLASH FILE CID:53 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed resetting usercode.. smth wrong with usercode reset,error is: 1 Error while resetting usercode. writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 560 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\com81\Desktop\New Folder\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID 49_DB2020.ssw CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:40 HDR block not accepted,error: 19 Elapsed: 14 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35901901402403 Model:K530c Brand:Generic MAPP CXC article: R8BA024 prgCXC1251059_CHINA_NS MAPP CXC version: R8BA024 Language Package:CHINA CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1251063 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 18 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35901901402403 Model:K530c Brand:Generic MAPP CXC article: R8BA024 prgCXC1251059_CHINA_NS MAPP CXC version: R8BA024 Language Package:CHINA CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1251063 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed FORMAT GDFS SKIPPED,ENABLE ALTERNATIVE SECURITY BYPASS will write 1884910147 variables gdfsWrite err:A,block:54,unit:3176 Exception in GDFS write. maybe bad gdfs file. done Failed. Elapsed: 47 secs. POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed FORMAT GDFS SKIPPED,ENABLE ALTERNATIVE SECURITY BYPASS will write 1330 variables done Phone detached Elapsed: 75 secs. SIGNED MODE (USING SERVER). bad username/password. CARD COUNTERS: FLASH 69, UNLOCK 103 Elapsed: 16 secs. SIGNED MODE (USING SERVER). bad username/password. CARD COUNTERS: FLASH 69, UNLOCK 103 Elapsed: 7 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed resetting USERCODE.. smth wrong with usercode reset,error is: 1 Error while resetting USERCODE. Elapsed: 57 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35901901402403 Model:K530i Brand:Sony Ericsson MAPP CXC article: R8BA024 prgCXC1251059_CHINA_NS MAPP CXC version: R8BA024 Language Package:APAC CDA article: CDA102568/101 CDA version: R8A Default article: cxc1250959 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 7 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\com81\Desktop\k530\cid52\r6bc002\R6BC002_ CXC1250912_NC_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 HDR block not accepted,error: 19 Elapsed: 11 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\com81\Desktop\New Folder\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID 49_DB2020.ssw CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:40 HDR block not accepted,error: 19 Elapsed: 10 secs. SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed FORMAT GDFS SKIPPED,ENABLE ALTERNATIVE SECURITY BYPASS will write 1936090215 variables gdfsWrite err:A,block:77,unit:6972 Exception in GDFS write. maybe bad gdfs file. done Failed. Elapsed: 59 secs. SIGNED MODE (USING SERVER). file can't be found or opened Elapsed: 0 secs. SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed FORMAT GDFS SKIPPED,ENABLE ALTERNATIVE SECURITY BYPASS will write 1936090215 variables gdfsWrite err:A,block:77,unit:6972 Exception in GDFS write. maybe bad gdfs file. done Failed. Elapsed: 59 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed resetting USERCODE.. smth wrong with usercode reset,error is: 1 Error while resetting USERCODE. Elapsed: 61 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35350002966711 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35901901402403 Model:K530i Brand:Sony Ericsson MAPP CXC article: R8BA024 prgCXC1251059_CHINA_NS MAPP CXC version: R8BA024 Language Package:APAC CDA article: CDA102568/101 CDA version: R8A Default article: cxc1250959 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. |
09-29-2008, 20:21 | #10 (permalink) |
Junior Member Join Date: Aug 2007
Member: 573135 Status: Offline Thanks Meter: 15 | first u run truth the cid 53 just tick complete phone n use sign mode server after that try to find 1 sim card with means the phone lock by what operator sim insert it and run pls tick as below use sign mode server/alternate by pass/complete phone/unlock after flash/format gdfs after u run the will show u insert sim card disconnect the phone and on back the phone plug in again the cable until u sea <phonemode>tune to phone mode until the driver detact the com port than remove the cable press resdy to flash again until end the flashing,hat all |
10-24-2008, 14:42 | #11 (permalink) | |
Member: 655012 Status: Offline Thanks Meter: 26 | Quote:
thanks sir but my phone not network locked it is imei mishmatch i have no original gdfs so how i repair imei | |
12-04-2008, 18:05 | #14 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 388978 Status: Offline Thanks Meter: 88 | Quote:
The error is at here " Restore from:R6BD001_CXC1251021_HUTCHISON_NC can't open file "C:\Documents and Settings\inex\Desktop\v0.914038\rest\R6BD001_CXC12 51021_HUTCHISON_NC"". In your rest file data have got an error file is: R6BD001_CXC1251021_HUTCHISON_NC. You have to download and unzip it from setool support website, again. I think unlock it will be ok. | |
K530i cid 53 after unlock dead flash lock | rockindheeraj | SETool2 | 11 | 09-02-2010 13:21 |
k530i cid 53 Could not start GDFS service Error: Could not initialize GDFS access. | kyaw8719 | Cruiser Suite | 3 | 03-03-2010 14:42 |
how to repair gdfs k530i cid 53 ? help cruiser team | kyaw8719 | Cruiser Suite | 3 | 03-01-2010 08:10 |
plz i need gdfs for k530i cid 53 | med26 | Sony Ericsson | 1 | 02-28-2010 21:21 |
cid 53 problem sim lock | ranlab | Sony Ericsson | 3 | 11-24-2008 15:10 |
