Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-04-2008, 05:59 | #5 (permalink) |
Insane Poster Join Date: Aug 2005 Location: Perú Age: 43
Member: 173206 Status: Offline Thanks Meter: 44 | This solution is for no keypad w610 or k550i... 1. check and clean conector keypad to board 2. measure the continuity of the tracks 3. replace board keypad 4. check switch closed (key volume, play, stop etc) but if not none of that replace chip db20xx internal esd proteccion "MARIKA_SECURITY_EFUSE" 100% solution!!! luck to all!!! |
The Following User Says Thank You to libra202 For This Useful Post: |
07-16-2008, 10:52 | #10 (permalink) |
Freak Poster Join Date: Jun 2005 Location: iran-kashan Age: 44
Member: 157053 Status: Offline Sonork: 100.1606219 Thanks Meter: 489 | k550 havent any keypad ic my friend k550 have not key pad ic and keypad way go to cpu from keypad connector .if your uif and connector are good.you should change cpu and flash and do empty fill with setool click on thanks bottom for more help |
The Following 21 Users Say Thank You to morteza-icu For This Useful Post: |
07-16-2008, 11:41 | #11 (permalink) | |
Insane Poster Join Date: May 2006
Member: 276060 Status: Offline Thanks Meter: 9 | thankx Quote:
thank you again for answer and this is a big thank thank youuuuuu | |
07-16-2008, 11:43 | #12 (permalink) | |
i find the probleme in the soket key of th pcb and this is a big thank thank youuuu | |
The Following 3 Users Say Thank You to nabil_alg For This Useful Post: |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
k550 keypad problem | mobilehut1 | Sony Ericsson Hardware Repair | 18 | 05-10-2011 02:48 |
K550 Keypad Ways Solution | 2lits | Sony Ericsson Hardware Repair | 14 | 12-27-2010 22:49 |
SE W880 / W610 / K550 supported now! | WotanServer.com | WotanServer | 0 | 02-14-2007 19:44 |
K550 Looking "Demo" On Display | lahoot | Cruiser Suite | 8 | 06-12-2006 10:19 |
