Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-04-2006, 07:52 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 270865 Status: Offline Thanks Meter: 0 | K600i partial stick and keypad malfunction I have the following strange(?) problem with my K600i. Sometimes the joystick does not work in both the rigth and up-direction but 'down' and 'left' work well. Furthermore the volume keys, the shortcut key and the camera trigger (all on the phones right side) do not respond. Sometimes the joystick and all other keys work fine. I have dismanteld the phone and discovered the following. Shortcut and camera key are parts of the K600's keypad but volume keys and joystick are soldered on the boards surface. If have cleaned the keypad cable. After that all keys and the stick worked for one day (maybe accidentally?) but now I have the same problem as before. I do not asume the joystick or one button is broken because either all buttons and the stick work perfectly or the described buttons and 2 stick direction do not work at all. I also do not beliefe the keypad cable is broken, 'cause some keys are soldered on the board an others are part of the keypad. What's going wrong here? Any ideas? Regards Bioabfall |
10-12-2007, 15:14 | #4 (permalink) |
Freak Poster Join Date: Sep 2005 Location: USA Age: 58
Member: 176971 Status: Offline Thanks Meter: 116 | my mistake, man...sorry....that answer was for a different phone. so, here is some pictures already posted in this forum: |
The Following User Says Thank You to edi_vladut For This Useful Post: |
7210c keypad malfunction up,down and call need help! | margallo | Nokia Hardware & Hardware Repair | 4 | 09-10-2010 07:39 |
t230 keypad malfunction | katicutie | Sony Ericsson | 7 | 06-09-2006 13:04 |
T230 keypads malfunction | ber747 | Sony Ericsson Hardware Repair | 6 | 08-21-2005 09:30 |
509 keypad malfunction... read on :) | trafix | Various | 9 | 03-02-2002 09:24 |
S25 keypad malfunction | CellM@n | Siemens Hardware Repair Area | 6 | 07-29-2001 11:35 |
