Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-07-2007, 13:27   #1 (permalink)
Member: 509782
Thanks Meter: 4
k610i mic problem
i have k610 mic problem...when talking mic only very slow...can anyone tell me where is the mic ic or any solution....urgent,thanks
The Following User Says Thank You to boy7000 For This Useful Post:
Old 09-21-2007, 10:38   #2 (permalink)
Member: 16943
Thanks Meter: 35
hi
i have similar problem, after water i have no mic, help please
thanks
Old 09-21-2007, 10:48   #3 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 437
change the mic carefully
Old 09-24-2007, 16:51   #4 (permalink)
Raa_z's Avatar
Member: 471777
Thanks Meter: 55
Arrow
try with hansfree Raa_z
Old 09-25-2007, 11:59   #5 (permalink)
Arief Kasali's Avatar
Member: 327733
Thanks Meter: 38
Wink
Originally Posted by jak2812 View Post
hi
thanks
Change with mic nokia 5200/5300. but if connected you don't use hot air. you can make jumper. I have tested & 100% work.
The Following User Says Thank You to Arief Kasali For This Useful Post:
Old 02-23-2008, 13:13   #6 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 394
K610 mic solution..
regards..
The Following 25 Users Say Thank You to iqballk For This Useful Post:
Old 11-23-2008, 15:26   #7 (permalink)
Member: 91248
Thanks Meter: 8
Put new mic with 2 very thin wires to mic pads, not direct to pcb because you will overheat new mic, tested on few new mics. No matter where (under or over pcb) you will put hot air, each mic will be overheat.
I used mic from nokia 6111. Works perfect, i think better than original working phone.
Old 11-24-2008, 09:45   #8 (permalink)
Member: 12388
Thanks Meter: 22
k610 headfree appear on display.......... help me pls
Old 11-24-2008, 15:29   #9 (permalink)
Member: 565282
Thanks Meter: 22
try this sir
good luck
The Following 19 Users Say Thank You to supersonic-x For This Useful Post:
Old 12-04-2008, 18:11   #10 (permalink)
Member: 767784
Thanks Meter: 21
k610 mic
use samsung e700 mic no need wire jumper just use mic flax which is fix on mic.
The Following User Says Thank You to maf2ir For This Useful Post:
Old 02-20-2009, 11:53   #11 (permalink)
: ronfreek :'s Avatar
Member: 134949
Thanks Meter: 200
if you will use original mic with heat not more then 350 degrees
then the mic will work
tested for many units
br ron
Old 08-07-2009, 09:11   #12 (permalink)
Member: 482670
Thanks Meter: 125
my k610i is lose track of both,, how to conect ?? any solution ??
Old 08-19-2009, 18:24   #13 (permalink)
Member: 275689
Thanks Meter: 64
can you please give some step-by-step instructions on how to put a new mic on k610i, coz i have never done this before. what to solder and where? please provide some video tutorials or any other manual for beginners. thnx.
The Following User Says Thank You to most_powerful For This Useful Post:
Old 08-20-2009, 06:31   #14 (permalink)
Member: 482670
Thanks Meter: 125
use nokia 5300 mic modify it ,, sound clear n nice .. cheers
Old 08-26-2009, 17:10   #15 (permalink)
Nurettin Duman's Avatar
Member: 115596
Thanks Meter: 1,120
Thumbs up V630i-K610i-MIC
V630i-K610i-MIC ..................
The Following 5 Users Say Thank You to Nurettin Duman For This Useful Post:
SE K610i backlight and mic problems nikolazz Sony Ericsson Hardware Repair 1 05-19-2010 15:50
Sony Erricson K610i mic problem georgeo2010 Sony Ericsson Hardware Repair 1 09-11-2009 12:08
sony ericsson K610i mic problem mazeegar101 UFS2 + UFS3-Tornadoflasher 2 11-24-2008 15:27
K610i mic ways,schematics [email protected] Sony Ericsson Hardware Repair 3 09-29-2008 02:53
K610i mic problem ecu977 Sony Ericsson Hardware Repair 0 12-25-2007 02:05
Page generated in 0.45186 seconds with 9 queries
