Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-15-2006, 00:36 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 388705 Status: Offline Thanks Meter: 0 | k700 keypad issue Please help...Thanks. |
11-15-2006, 14:14 | #2 (permalink) |
Junior Member Join Date: Oct 2006
Member: 382043 Status: Offline Thanks Meter: 0 | Hi I have same Problem for k750i 1, 2, 3, *, #, OKkey joyRight and joyDown dont work and won't power off but the click sound works when pressed, seems to be a simple problem to fix but how do you check which IC is working or not (what tester to use), also what are the components called (reference to buy for replacement). any HELP greatly appreciated. |
11-15-2006, 15:31 | #3 (permalink) | ||
Freak Poster Join Date: Apr 2005 Location: SA TO UK
Member: 136823 Status: Offline Thanks Meter: 50 | Quote:
Ok both of you need to change the keypad control ic which is located above right of joystick. The ic has 3 diodes to the left and 1 above and 1 below. Hope that helps MRL | ||
11-16-2006, 01:11 | #5 (permalink) | |
For K750 next to the joystick on the right there is a square componet has sort of a glass effect change that... sorry dont have any pics but will up load soon Hope that helps | |
11-17-2006, 18:36 | #6 (permalink) |
Member: 382043 Status: Offline Thanks Meter: 0 | hi thanks for reply i will try this i have a spare k750i for bits my brother also had similar problems and he updated his firmware to w800i using w800i.exe and fixed his keys but he is starting to get keys working now and then maybe it was just a coinsidence anyway thanks for help. |
C902 keypad issues | akash84 | Sony Ericsson Hardware Repair | 3 | 02-04-2012 15:30 |
d900 keypad issue! | simsin | Samsung Hardware Repair | 2 | 04-08-2009 01:13 |
3220 Keypad Issue | picks | Nokia Hardware & Hardware Repair | 8 | 11-29-2008 16:20 |
K700 keypad | saso | Sony Ericsson Hardware Repair | 0 | 07-25-2005 23:23 |
7210 keypad issue | kaspa_lee | Nokia Hardware & Hardware Repair | 1 | 10-01-2003 02:40 |
