Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-26-2005, 22:07 | #1 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 52
Member: 103401 Status: Offline Thanks Meter: 3 | K700 no microphone-help pls BR. |
02-27-2005, 19:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | you can heat gently to replace this circiut , back to position. if, you are not clear , you can sent me a email . [email protected] bestman |
03-23-2005, 11:33 | #3 (permalink) |
Freak Poster Join Date: May 2004 Location: Proud Serbia
Member: 65352 Status: Offline Thanks Meter: 118 | I have same problem! One of crystal IC near mic contacts is broken(first near mic contacts),can i change that with crystal IC from SE T310,are they same??? please help!!! B.R. MADCIRA |
03-24-2005, 16:28 | #5 (permalink) |
Junior Member Join Date: Jan 2005 Location: Macedonia Age: 53
Member: 110512 Status: Offline Thanks Meter: 0 | If you look the PCB from behind(the SYS conn is down). Then the MIC contacts are last 2 in the lowest row and other 2 are last 2 in the highest row. Hope this helps AND GOOD LUCK WITH BRODGING. O I forkgot to mention... if PCB is from the latest production then it is all LEAD FREE so be careful. |
03-24-2005, 16:52 | #6 (permalink) | |
Member: 65352 Status: Offline Thanks Meter: 118 | Quote:
Crystal IC is 4x5 you mean on that bandage- last 2 in lowest row and last 2 in the highest row.That 2 contact under IC, i must short them or one by one with wire connect to mic contacts??? Have you schematics for k700,it would be useful!!! B.R. MADCIRA | |
03-30-2005, 08:20 | #9 (permalink) |
Member: 110512 Status: Offline Thanks Meter: 0 | Looking from the top and SYS conn. in the bottom. Counting from left to right.In the first row 4 and 5 and in the last (4) row 4 and 5. Bridge 4 with 4 and 5 with 5. Dont touch the mic contacts or anything else.Hope this helps. I dont have shematics |
06-08-2005, 16:11 | #13 (permalink) |
Junior Member Join Date: Jun 2005 Location: POLAND Age: 42
Member: 151259 Status: Offline Thanks Meter: 0 | Hello I have tested this Crystal from T610 put in k500i but you mast rotate right http://forum.gsmhosting.com/vbb/show...4&page=2&pp=15 |
k700 no charge.....help me!!!!!!!! | TOGOX77 | Sony Ericsson Hardware Repair | 3 | 07-17-2008 18:49 |
3230 lcd no light...help pls? | jimmyyew | Nokia Hardware & Hardware Repair | 7 | 11-29-2006 12:33 |
w800 no network help pls | nafg | Cruiser Suite | 2 | 12-11-2005 16:51 |
6600 after flash no power!!!!help pls!!! | jason_ting | Nokia Hardware & Hardware Repair | 5 | 07-02-2005 12:22 |
Maxon 6869 LCD no display, help PLS! | Ken-mkII | Hardware Repair by brands | 0 | 05-21-2002 16:20 |
