Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-07-2007, 09:32   #1 (permalink)
Member: 2716
K700i network problems
Hello,
I cleaned one K700 after water damage and everything was working fine for several days.
Now it can register to network without problems but can not make or receive calls. When I try to dial number it just return back to main screen. When I try to call it from another phone, I am getting "user not reachable" or "user has switched off" announcements.
Tried to clean it again, reflow, reflash. Nothing helped.
Any hints?
Thank you.
Old 06-07-2007, 12:00   #2 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
check your intena conetions if they are working good then write gdfs to phone.........
Old 06-08-2007, 07:57   #3 (permalink)
Member: 2716
Thank you for help.
I tried that already and still nothing. Maybe some other idea?
Regards.
Old 06-08-2007, 09:41   #4 (permalink)
Member: 388978
Thanks Meter: 88
resold RF IC. Network is well. (sure)
Old 06-15-2007, 18:40   #5 (permalink)
Member: 180758
Thanks Meter: 13
pull out the antenna switch and connect the first,7th and the 13th legs of the antenna switch(see previous posts on antenna switch bridge for k700i).do not replace it.If not ok ,then change the pa.
Old 06-18-2007, 11:32   #6 (permalink)
Member: 180758
Thanks Meter: 13
Heat pcb on a 40 watt electricity bulb for about two hours.Change position every 25 minutes to avoid damage and to allow all parts of pcb are heated.Reason :I still think there is some water locked in the major components especially the antenna switch and the pa.All the best.
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
K700i charging problem simono_xm Sony Ericsson Hardware Repair 17 06-09-2006 10:17
K700i headset problems rikesh Sony Ericsson Hardware Repair 3 03-13-2005 11:16
K700i with problems... FLaMeWaRe TOTAL MultiServer 3 12-20-2004 18:03
K700i BT problem after flash/decustom. pali Griffin 6 12-05-2004 10:18
Page generated in 0.17363 seconds with 9 queries
