Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-19-2006, 09:34   #1 (permalink)
Member: 240930
Red face K750 battery charge low fastly!!
My custumer have a k750 and when he want charged it the phone very
warmed . now battry charge lowed very fastly .I try flash it by
setool3 but not boot phone i use test point but not boot again.
i changed v2681 and v2802 and remove n2802 but the phone not boot for
flash and charge battry lowed fastly,i changed battery but it have some problem !!!
what is problem?
Old 12-19-2006, 17:53   #2 (permalink)
Member: 240930
any help please K750 battery charge low fastly!!
Old 12-20-2006, 03:20   #3 (permalink)
GSM_BLUE's Avatar
Member: 356202
it might be battery problem.. but the most possible is the set is shorted or has a leak.. check battery connector + and - with multi tester..
if the set is short.. isolate PA by removing the coil beside pa..
br
Old 12-21-2006, 10:06   #4 (permalink)
Member: 240930
any body help me about K750 battery charge low fastly!!
Old 12-24-2006, 14:20   #5 (permalink)
Member: 240930
Old 05-01-2007, 09:20   #6 (permalink)
Member: 240930
br
what mean:
Old 05-02-2007, 08:21   #7 (permalink)
GSM_BLUE's Avatar
Member: 356202
thats the possible first step solving your problem..
wbr
Old 05-04-2007, 11:00   #8 (permalink)
Member: 368438
%100 k750i bettry discharg
%100 k750i bettry discharg i tested me
The Following 5 Users Say Thank You to zahidgsmx For This Useful Post:
Old 11-29-2007, 15:54   #9 (permalink)
dandylion's Avatar
Member: 236929
Thanks works a treat
Dan
The Following User Says Thank You to dandylion For This Useful Post:
Old 11-29-2007, 16:28   #10 (permalink)
Member: 344164
thanks man it works in k750
The Following User Says Thank You to jack81 For This Useful Post:
Old 03-03-2010, 01:19   #11 (permalink)
Member: 749092
thanks for zahid cause my broplem is solved
thank you zahid again
Old 05-06-2010, 13:25   #12 (permalink)
Member: 116294
thanks zahidgsmx............
Old 01-26-2011, 09:50   #13 (permalink)
Member: 957988
thank youuuuuuuuuuuuuuuuuuuuuuuuuu
Old 08-13-2011, 06:11   #14 (permalink)
Crazy Poster
Member: 1181938
may be ok for k 750i but for w 700,removing this component results in white screen.....
k750 battery low germany Sony Ericsson Hardware Repair Area 8 06-25-2012 06:54
cect p168c not charge,low voltage 2,5v on battery pin solution? nykocam Chinese Models & Cloned Phones 3 03-09-2010 06:56
nokia 6600 low battery charge problem mathai69 Nokia Hardware & Hardware-Repair Area 0 10-06-2009 07:37
p990i charging but battery still low bat. johed Sony Ericsson Hardware Repair Area 0 05-05-2009 05:49
1100 fast charge & fast decharge kevin2001 Nokia Hardware & Hardware-Repair Area 3 02-08-2008 09:13
Page generated in 1.24989 seconds with 12 queries
