Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-12-2008, 14:35   #1 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
k790i error
v0.915021/UNI
CARD SERIAL: 0000xxxx
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A
FLASH CID:52 COLOR:RED
setGDFS_params failed
failed to setup GDFS
Elapsed: 62 secs.
i am confuse about cid 51 , cid 52
lp. help
Old 12-12-2008, 15:55   #2 (permalink)
Member: 240856
Thanks Meter: 82
Dear CID 52
Old 12-13-2008, 13:49   #3 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
Open COM port OK
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
USB CONNECTION REQUIRED.
Elapsed: 8 secs.
ALTERNATIVE SECURITY BYPASS DISABLED !
ENABLE "SIGNED MODE" !
Open COM port OK
Speed:921600
phone CID not supported in that mode
Elapsed: 3 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
writing C:\Documents and Settings\omkar\Desktop\R1KG001_FS_AMERICA_2_EV_RED _CID52.ssw
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is:4260
Will flash 213 blocks...
SSW loading returns:0
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed (1D)
loader GDFS startup failed, that is fatal
Elapsed: 244 secs.
READ GDFS
Will backup GDFS now.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 16 secs.
FLASH OK BUT SHOW GDFS ERROR, NO READ GDFS
I TRY WRITE GDFS
The Following User Says Thank You to omkarvitekar For This Useful Post:
Need HELP K790i flashing | Error flashing block at address: 0x44140000 galerinisan Cruiser Suite 4 06-03-2008 18:06
k790i configuration error. .. harish35200 Cruiser Suite 12 01-03-2007 06:35
configrasyon error after flash k790i senkron24 Cruiser Suite 15 10-27-2006 16:56
k790i error 002B41 sankokai TOTAL MultiServer 3 10-25-2006 21:39
Page generated in 0.12536 seconds with 9 queries
