Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-06-2006, 15:48 | #16 (permalink) | |
Freak Poster Join Date: Mar 2000 Location: Bulgaria Age: 54
Member: 1128 Status: Offline Thanks Meter: 13 | Quote:
The Following User Says Thank You to Sandino For This Useful Post: |
09-08-2006, 01:38 | #17 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 47
Member: 78679 Status: Offline Thanks Meter: 3 | folks! all is said and done? this are quet enormouse task, the schematic diagrams is what is needed here.thanks all the same. |
The Following User Says Thank You to adomshima For This Useful Post: |
09-12-2006, 15:28 | #18 (permalink) |
Major Poster Join Date: Jun 2006
Member: 293272 Status: Offline Thanks Meter: 8 | hello,can u give me idea on how to replace the mic of k750i? im having problem with mic, do you have schematic r diagram on how to do it ... thanks |
The Following User Says Thank You to gachero For This Useful Post: |
09-15-2006, 15:43 | #20 (permalink) |
Member: 293272 Status: Offline Thanks Meter: 8 | k750i mic i change the mic using t610. with 1.2k resistor,in series with it, its working rirht now... thanks for the solution..... |
09-15-2006, 15:44 | #21 (permalink) |
10-06-2006, 09:29 | #22 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | k750i mic problem substituting k750i mic with t610(with series 1k resistance) works 100% THANKS FOR THE SOLUTION |
The Following 2 Users Say Thank You to .:*CHENNAI GSM*:. For This Useful Post: |
10-15-2006, 11:44 | #23 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
can this make the problem before i try to replace mic ? | |
The Following User Says Thank You to TRABEL For This Useful Post: |
02-09-2007, 21:30 | #28 (permalink) |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | Hi I removed my K750i mic with a sharp blade, but how can I measure e 1.2K resistor in other phones??? |
The Following User Says Thank You to Black_Daimond For This Useful Post: |
02-10-2007, 15:30 | #30 (permalink) |
Member: 179391 Status: Offline Thanks Meter: 57 | O.k I fixed mines. My problem was that I dont have a technician background, but trying we can get solution 4 everything. I have a waterdamage Nokia 3310 ordinaire Board. In between the sim-connectors (just were the simcard connects to the PCB) I took the smallest shiny black part (there are 2 of them). According to the Schematics attached above by MUJIE, I soldered this small Resistor, without knowing it is K1.2 or not, to the board where it is draw to be soldered. Its was to small and it did not reaches the other edge, so I have use a tin aerpeace wire, the colored one, to join it to the + on the K750i PCB to the + of mic. (mic I took the K300i very small round mic) I soldered the mic face down to the hole in the K750i PCB I have used the base off the mic and soldered directly to the ground of BCP where the - of mic should be soldered. On the K750i PCB there is 3 Negative points. 2 points right behind where the resistor K1.2 should be soldered, and all around the hole where the voice goes thru. I have used the 2 points of negative to ground the mic Read this info, analyse it good, and you will easely fix your K750i or W800 mic problem. Thanks to all we give advise! Last edited by Black_Daimond; 02-10-2007 at 15:41. |
E250 microphone ways (E250 microphone broken roads) | BULUTHAN | Samsung Hardware Repair | 1 | 12-28-2009 10:59 |
sonyericson K750 microphone failure | harveyguy79 | Sony Ericsson Hardware Repair | 0 | 02-04-2008 07:48 |
k750 MICROPHONE PROBLEM AND MEM. CARD PROBLEM | PhoneDoctor | Sony Ericsson Hardware Repair | 0 | 11-14-2006 13:11 |
k750 and microphone | Worky | Sony Ericsson | 0 | 11-17-2005 13:45 |
K750 DavinciTeam NEW!!! K750 flash via original DCU-60 cable | GsMen | Main Sales Section | 0 | 06-20-2005 03:45 |
