Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-03-2007, 11:23   #1 (permalink)
hooi76's Avatar
Member: 7741
K750 when insert memory card, the LCD blink
it's a water damaged phone and i found out that tis ic is damaged, N2980, is this ic compatible with 7250i camera ic? it's 5 leg
Old 12-15-2007, 02:43   #2 (permalink)
Member: 186289
good info thanksssssssssssssssssssssssssssssss
Old 12-15-2007, 04:26   #3 (permalink)
Temporary banned !!
Member: 546766
i have d800 its same problem.........................
Old 12-28-2007, 07:43   #4 (permalink)
mobilehut1's Avatar
Member: 481123
any jumper for this ic?
Old 02-09-2008, 05:48   #5 (permalink)
Member: 398448
u mean its compatible with 7250i camera ic ??
and are u tested ???
Old 02-11-2008, 19:10   #6 (permalink)
pepik's Avatar
Member: 62102
Blinking LCD is cause /when memory card inserted/ cause bad filter /90%/ for memory IC or bad Memory Cardx /10%/.
Try to make this : remove BGA IC and make this jumper :
The Following User Says Thank You to pepik For This Useful Post:
Old 02-12-2008, 11:43   #7 (permalink)
Member: 191089
nice solution thanks
Old 02-12-2008, 19:50   #8 (permalink)
Member: 385685
thankssssssssssssssssssssssssssssssssssssssssssss
W380 LCD Blank When Insert Memory Card mtech6928 Sony Ericsson Hardware Repair Area 6 08-21-2009 22:26
v360 hangs when inserting memory card yurais Motorola Hardware Repair Section 1 12-01-2007 04:55
K750i goes white dispaly when insert memory card matrix123 Sony Ericsson Hardware Repair Area 5 07-01-2007 19:45
7610 When Insert Memory Card PARMATMA Nokia Hardware & Hardware-Repair Area 11 05-04-2006 21:33
3650 hangs when inserting memory card forhike WD2 & APE (Symbian Phones) 2 08-21-2003 03:02
Page generated in 0.34967 seconds with 12 queries
