Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 191662 Status: Offline Thanks: 1
| K750i backlight/screen light does not light up Can use the phone but screen light does not light up!! Anyone got a solution to this problem???? THANX IN ADVANCE |
| | #5 (permalink) |
| Junior Member Join Date: May 2006
Member: 275109 Status: Offline Thanks: 0
| hello.. i just had the same thing happen with the backlight on my k750i today. bought the phone on ebay about 3 weeks ago. the thing was perfect.. not a scratch. after not using the phone in ANY adverse conditions, today, i picked up the phone and the backlight would not come on. i turned off the phone and turned it back on.. the light came on, but only until it went to sleep. then it would not come back. after that, even turning it off and back on again, the backlight would not come on. I've taken the phone apart and can not find anything fishy looking around the LCD connector.. nothing obvious anyways. any expert opinions?? |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004
Member: 68105 Status: Offline Thanks: 1
| Why did you schemtics...change only LED driver ..........you can use a a 6230/K700 LED driver...works fine quick quesyion about k750/2800 lcd |
| | #8 (permalink) |
| "display connector or dcdc converter" 1. what is a dcdc converter? 2. are you saying that these are the probable causes of the problem? 3. is it not possible that the LCD itself is broken? |
| | #10 (permalink) |
| thanks for the reply.. thought i don't really like the prospect of taking a soldering iron to my phone. you don't think replacing the LCD will fix the problem? |
| | #11 (permalink) | |
| Quote:
No........................ | |
| | #12 (permalink) |
| you were right, changing the lcd didn't work. so which option would you reccomend i try first, changing the LED driver, or soldering a new connection by the LCD connector? (i assume that picture above is of the LCD connector) |
| | #13 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2002 Location: Shenzhen China Age: 57
Member: 16350 Status: Offline Sonork: 110823 Thanks: 28
| Quote:
*** bless you're post sir as i just tested on water damage phone and i can say that on this first ocasion the solution is 100% ... Thanks and pls do me another favor and tell me how that u manage to comprehend this problem?? br | |
| | #14 (permalink) |
| opo, good to hear someone has done this with success! if you would, could you please say: 1. how you obtained a replacement LED driver? 2. how did you install it? I would VERY much appreciate knowing this. thanks. |
| | #15 (permalink) |
| Junior Member Join Date: Jun 2006
Member: 298984 Status: Offline Thanks: 0
| I have the same issue my backlight for LCD is no longer working after replacing my camera and putting back together. copper clips are both in place. I did manage to get it lighting up at one point but even when it was it was super bright and you could not adujst the brightness in the menu. Now I can no longer get the backlight on at all. Not sure if I am having the same LED driver issue or not. If so the soldering looks a little to fiddly for me. Any other ideas? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| K750i than change V2628 does not see Memory Stick | maxmyd 3 | Sony Ericsson | 1 | 11-09-2009 18:30 |
| 3120c side of the screen does not light | uzmantel | Nokia Hardware & Hardware-Repair Area | 3 | 06-06-2009 16:12 |
| Nokia 6230 does not power up and not charging | mobileunlockers | Nokia Hardware & Hardware-Repair Area | 0 | 11-26-2006 19:54 |
| Blazer Problems - Does Not Load Up 2nd Screen | nokia6188 | Blazer | 4 | 01-21-2005 17:44 |
| Two 3888 does not power up. Help! | mastergsm | Old Legacy Motorola (EMMI) | 1 | 09-20-2004 14:26 |
